what cage
what cage
What time in the 1/4 will you need a 10point cage? Also who makes 10point cages for an 01 camaro? Does it need to be welded in? Then, how will it fir the car with the a-pillar situation? Thanks.
Id want one if I was running 115+ .. you can wreck really hard at 100mph
I think it's 10.99 ( I'm not 100% sure)
Must weld in ...
Fit depends on the kit or if you go custom, depends on the installer ..
Go with moly if you can afford it, it's stronger you can use less wall thickness and it will be less weight than M/S
Must weld in ...
required at 9.99 or 135, provided you have unmodified firewall or floorboards.
Front bar style is a matter of personal preference, can go thru the dash or around the dash, but you can never remove the dash again if you go around. Best to go through.
Here is what mine looks like (custom bent):
https://ls1tech.com/forums/drag-racing-tech/448652-rollcage-pretty-much-complete-pics.html
