Anyone Install SLP Line lock Come UP!
I started my install last night and it went real easy putting the new brake lines on, then running the wire from the switch to the actuator
The install instructions say to run the wire inside the main wire loom from the drivers side to the passenger side, then through the firewall back to the actuator, I would say it is impossible
Anyone got a quick fix to get the wire through the firewall, I couldn't even find a place to squeeze it through or drill a new hole, man it is tight all over!
Thanks for any help.
theres a grommet under the computer that the main wires go through. if you want easy access to it just remove the mounting bolts to the computer and move the computer off to the side, otherwise, go inside the car, remove the pass. kick panel and door sill, reach up as high as your arm can reach and its right there. push the grommet to the side and run the wire through. ive done it for a 4guage amp wire, my shift light, nitrous wires, etc. just feed some wire loom down the wire to protect it from rubbing against the metal. hope this helps.
Jeff,
thanks for the help! That makes sense.
I talked to the SLP tech line folks and it was obvious, the guy had never installed one.
Have a good one and thanks again.
Mike
Mike
no problem, ive been in that area more times than i can count, havent had to move the computer a single time. if you have trouble feeding the wires, sometimes a coat hanger can help.
SLP line lock
