Drag Racing Tech
et street radial size? and metric front runner?
Old 02-21-2006, 09:42 AM
slvrhwk's Avatar
Default et street radial size? and metric front runner?
What size do you think I would benfit from the most?
These will be on 8.5 convo pros.
MT ET Street Radial
275-50-15
26" tall,rim 8.5,tread.10.0
255-60-15
27.1" tall, rim 8.0,tread 8.8
275-60-15 (Will these fit in my wheel well without any mods?)
28" tall,rim 8.0, tread 9.2
By mid season the car will be making somewhere around 430rwhp and weight approx 3,450
Has any one ran 165-80-15 kumho for front runners?
Thanks
Old 02-21-2006, 01:09 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
The 275-60-15 is a narrow 28" tire, it will hook the best. But depending on your gearing it might eat up 1mph.
Old 02-21-2006, 02:21 PM
slvrhwk's Avatar
PSJ
The gearing is 411 with a m6. Can I clear the 28's without messing with the lip on the qtr?
Thanks
Old 02-21-2006, 06:46 PM
GTFORMULA's Avatar
I would run the 275-50-15 because they have more width. It will also not set off the ABS. I have had alot of sets of the 165-15's and they work great. If your set on the 28 inch tall then go with 325-50-15's.
Old 02-21-2006, 09:20 PM
LS1Tech Co-Founder
275-60-15 on a 15x8 will fit without major clearancing. A 325 won't.
Old 02-21-2006, 10:58 PM
badass 2002 z28's Avatar
275/60-15 will fit a 15x8 without any clearancing..they're only a 9" tire
Old 02-22-2006, 08:43 AM
gator's 99TA's Avatar
+1
i have done this exact combo. no clearancing needed at all. on a 10" rim its only minor stuff ( bumpstop removal and slight banging with BFH)
Old 02-22-2006, 09:17 AM
slvrhwk's Avatar
Thanks ordering today
Old 02-22-2006, 02:01 PM
Retired Street Racer
Matt D's Avatar
I would go with the 275/60/15s as well. MT doesn't make a 255-60-15 btw.
Old 02-23-2006, 07:40 AM
you can buy the 255/60/15 from jegs right now. its a 27x8.8x15 radial.
Old 02-23-2006, 09:33 AM
Race your car!
JL ws-6's Avatar
I was plannign on the 275 60 15 tire.. but they are going on my 15 x 9.75 bogart welded rt's.. .I didn't have to clearance anything at all for a 26 x 11.5 et street, so I doubt I'll have to do anything for these either. Who sells that metric fron tradial that you are talking about too? And what height is it in inches? I'm not concerned about the abs, as that's coming out of my car anyway, more for the ground clearance, as I will drive around some on this tire setup... probably about 80% of the 1500 miles a year I put on my car.
Quick Reply: et street radial size? and metric front runner?
