Speed Glass on the street?
Thanx.
My windshield had been cracked for a few months and i was going to replace it with Speedglass this month when my inspection sticker went out but the wedding is kiilin me so i decided to just put glass back in it.
I was going to eventually do speedglass front and back with a pin on hatch and keep the stock side glass. But i'm thinkin other wise now. hell i'm almost as light as the super light weights and still got another 100 lbs or so i could lose with out going speedglass and pin on hatch.
Percy's doesn't think it is a good idea.
I installed it in the rear of my car and they said it is not smart to glue the glass because they have seen multiple times that the glue didn't hold. I screwed mine in with the install kit they sell.
We at RPM are doing a complete set of speedglass on a shop car. We are going to use 3/16 front glass and I think that it is DOT approved. We will probably screw the front and the rear in. The sides will bolt to a prefabbed regulator. This by the way will be a complete street car. We have a goal of 2500lbs with a driver. Should be nasty.
LS1Tech Sponsor
Theglue I use will hold the Lexan in. The problems are the front and rear windows need supports in the middle to keep the window from bowing down at speed. The side windows WILLNOT stay in the car without a frame to hold the top when the window is in the up position.
Guess Who I do have a set of glass doors ready for windows I would sell.
how much weight would that take off if you did lexan in the back, it my kinda daily driver, and what about the front?? how much weight diff on the two, i want the back but not sure about the front
i dont want it to get all scratched up and everything and turn yellow
