Drag Racing Tech
What should I expect with 600 rwhp?
Old 02-22-2006, 03:12 PM
TS6
TS6's Avatar
Default What should I expect with 600 rwhp?
My car has been 11.58 at 3700 lbs and 11.45 at roughly 3600 lbs at 116.xx in sorta bad air. 60' times are usually in the 1.5x range and the car hooks great now. Its a H/C stock bottom end with a build 4L60E and 4200 stall, and all the bolt ons. I would estimate from the times its run its making maybe 430 rwhp (MTI stage 2 heads, 228/236 cam, 598/602 lift) according to a few different hp calculators (never been on a dyno). I am looking into changing alot of stuff and while the raceweight will still be 3700 I should have around 600 rwhp. I have a 12 bolt with 3.73 gears as well. 28" tire. I know its heavy, but I am 300 lbs myself and aside from losing the A/C and heat I am running out of weight reduction mods.
So with 600 rwhp what would be a realistic ET/ MPH? It will be a procharged stock displacement setup, if that matters. I see no reason 60' times wouldn't be in the 1.4's.
Thanks!
Old 02-22-2006, 03:19 PM
baddogz28's Avatar
I'd expect 10.70's at about 126. My $.02.
Old 02-22-2006, 03:39 PM
TS6
TS6's Avatar
Hmmmm...It went 10.85 at a similar weight with the same combo + a 125 shot at 127 and change, which might be 530 rwhp. I was thinking 10.50 at 129, but I've never been that fast so I am speculating.
Old 02-22-2006, 03:57 PM
baddogz28's Avatar
^^^ Yeah, you definetely didn't include that info in your first post.
Old 02-22-2006, 04:04 PM
TS6
TS6's Avatar
Yeah, but I'm not sure how relevent it is since we still have no idea how much power it was making on the bottle, it had 125 pills in it but with no W/B or tune it may have been rich or whatever. Man, if it was lighter it would fly! But I don't want to lose my A/C and stuff......
Old 02-22-2006, 04:51 PM
Pathological Modifier
Ryan K's Avatar
Low Tens with a good 60', I'd say 10.20-.30's with a true 600 at the wheels in an auto car.
Old 02-22-2006, 09:30 PM
TS6
TS6's Avatar
Well, now it looks like I might be going with the iron block so I'm gonna be closer to 3800 lbs. Damn, this thing is heavy. But my fat *** isn't helping either. I honestly don't see how guys get down to 3000 lbs, I mean I could swap seats, remove A/C and heater, remove airbags, and maybe find 20 lbs. worth of misc. **** to remove (fog lights, etc.) and I'm still gonna be 3300 lbs plus a driver.
Old 02-23-2006, 01:01 AM
Mr.Nitrous's Avatar
That is my experience with 600hp and a 3800lb car?
The car has run a best of 10.4 @ 129
Old 02-23-2006, 05:43 AM
tektrans's Avatar
I ran 10.8@123 with just under 450 rwhp at just over 3500lbs. I agree that at 3800 lbs you'll be in the low 10's. Put that pig on a diet and you'll be in the 9's. If you're going with the iron block you'll be able to run a bigger shot with a DP set up so you'll be over the 600 rwhp anyway.
Old 02-23-2006, 05:46 PM
TS6
TS6's Avatar
I'll be around 650 rwhp according to the builder. I'll run it like that then when I get the itch its gonna get lightened to go 9's. Can't wait!
Old 02-23-2006, 10:24 PM
tboysen00's Avatar
9s wow, i wish i could imagine 9s
Old 02-23-2006, 10:32 PM
Moderator
FANTAZ28's Avatar
my set up last year made 428 rwhp on nitrous and went 10.5x at 126 with a 1.42 60 ft, at about 3250 or so .................
in reality 600rwhp should get you well into the 9's...... but most people dont maximize the power buy having the right converter, gear etc....
Old 02-23-2006, 10:55 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,088 Likes on 716 Posts
At that weight, I'm thinking 10.3@133mph.
Old 02-24-2006, 06:26 PM
TS6
TS6's Avatar
I thought 133 is enough for a high 9? I just hope the car still hooks like it did before. I really need to lighten it up. I could do a tubular K member, but I just don't like the idea for a street car. I guess removing my nitrous system will shed about 30 lbs., and I can yank the foglights. I'm almost wishing I hadn't put the 6 pt. bar in last year, but at those speeds its a good idea I guess. I'll just find some 100 lb little dude to drive it once for a good timeslip to carry!
Old 02-24-2006, 09:47 PM
LS1Tech Co-Founder
3800 lbs with 600rwhp is not gonna 60ft as good as say a 3400 lb setup. I think my mph project might be even a little high but you never know.
Old 02-25-2006, 06:27 AM
Race your car!
JL ws-6's Avatar
If you are plannign on makign 650 to the tires, better start planning on scrapping that 4l60, it will probably work for the tuning, but be smoked after the first pull on the street, I don't care who built it. 650 rwhp, is th400 time. Get used to the thought and start planning for it. With that, then mid to low 10's should be no problem.
Old 02-25-2006, 11:05 AM
TS6
TS6's Avatar
Yeah, it might happen. But like Dan said, they have made more on their 4L60E's. I know FLT makes awesome trannys, but my guy really is good. I think both companies use the best parts available and if it breaks, I'll have my guy fix it and convert me to a 400 and sell my 4L60E for most of the cost. I just hate losing overdrive. Oh well, 3.73 gears and 28" tires should still let me cruise 65 anyway.
Old 02-26-2006, 12:30 PM
slow trap's Avatar
with 600-650 rw even at your weight i would pissed at anything under 130 mph.i'll sat you'll turn 10.20s at 131-133.
Quick Reply: What should I expect with 600 rwhp?
