Drag Racing Tech
Help front bumper brace
Old 03-11-2006, 08:38 AM
mvonada's Avatar
Default Help front bumper brace
Any tips on removing the front bumper brace, the foam blocks just hold it right there. Also what if anything have people done to support the bottom of the plastic bumper?
Thanks for any tips.
Old 03-11-2006, 08:43 AM
GM Muscle's Avatar
The foam clips to the impact bar and then the impact bar just unbolts. The underside of the bumper does clip to the impact bar but you can use some nuts and bolts to attach it to the radiator plastic like it was before. I just opted to cut off the whole underside of my bumper.
Old 03-11-2006, 03:09 PM
mvonada's Avatar
HEY GM THANKS. T
The problem is, I took all the nuts off the studs on the brace and there isn't enough room to push the brace forward so the threaded studs clear the holes. The foam blocks are between the brace and the front bumper and very little wiggle room.
Anyone else with help??? Thanks.
Old 03-11-2006, 08:12 PM
GM Muscle's Avatar
Your trying to do it with the bumper cover still on the car? If so, it doesn't take very long to pop the cover off. Not sure if you can even get it out with the cover on. Cutting the foam out won't work, it's suprisingly tuff to cut, very dense. You could probrably get a sawsall in there and cut the studs off each end of the impact bar, then you would have a shot at sliding it out.
Old 03-11-2006, 11:02 PM
mvonada's Avatar
Okay, now it makes sense with taking the cover off. I am a little slow on the up take so thanks for hanging with me and thanks for the help!!
Old 03-12-2006, 08:24 AM
GM Muscle's Avatar
No problem.
Old 03-12-2006, 03:17 PM
Racer8102's Avatar
Like GM said, save yourself some headache and take the front cover off will be a piece of cake after that.
Old 03-12-2006, 03:21 PM
foggedz's Avatar
How much extra weight do you think you saved by cutting off them mounts that the front bumper bolts to?
Old 03-12-2006, 06:34 PM
GM Muscle's Avatar
Impact bar was 15lbs, frame rail ends/impact bar mounts are 6lbs each, I didn't weigh the foam but it had to be atleast 5lbs. I also cut the nose down and pulled all the under car plastic and fender liners. Nothing like dropping 40-50lbs off the nose in an afternoon, for free to boot.
Old 03-12-2006, 06:46 PM
foggedz's Avatar
6lb each, thats pretty good. I already pulled the bumper support last year, just woundering if it worth my time to pull the cover back off to cut off the frame rail ends.
Old 03-12-2006, 06:50 PM
GM Muscle's Avatar
Yeah, it's deffinatly worth the time. Plus once you pull the bumper a couple times, you can do it in about 15 minutes.
Old 03-12-2006, 08:24 PM
skipperbisket's Avatar
what is the process of taking off the bumper?
Old 03-13-2006, 08:02 AM
mvonada's Avatar
Hey GM, finally got it off, 1st time out is a B#%*. Do you have any pictures of the skin on the bumper trimmed?? Also noticed it is real loose now, no problems, huh??
Thanks again for jumping in here!
Old 03-13-2006, 10:52 AM
383ss's Avatar
the foam is actually about 2lbs.
Old 03-13-2006, 07:57 PM
GM Muscle's Avatar
I just noticed you have a Firebird and I havn't seen the under side of the nose on one. Basicly, I cut away all the excess, so now the lower edge wraps under and then that's it. Also, the Camaro uses a "nub" on each fender that locks into the nose, I cut this off and replaced it with a bolt to keep the seem tight. It should be just alittle floppier than stock but not really floppy. If it's real loose for some reason you can run the risk of spider webbing the paint.
Old 04-05-2006, 04:35 PM
Bryan @ Speed Inc.'s Avatar
so yea... the front bumper cover being that actual outside painted front of the car right????
how do you get that off??? do you just cut the little plastic clips off and replace them? if so, then where to i get the little plastic clips to re-install the bumper cover?
Old 04-05-2006, 05:19 PM
bump?
Old 04-05-2006, 05:22 PM
GM Muscle's Avatar
The clips are reusable. Pry the center post up with a screw driver then use a pair of plies to pull it most of the way out, then you can remove the whole clip.
Old 04-05-2006, 09:26 PM
oh thanks... i didn't know they could be re-used.
