Manual master cylinder
Hi Guys,
I am wondering what manual master cylinder you guys are using.
Strange and Wilwood offer a few choices and they don't seem to be
terribly expensive. What size bore would be recommended?
I have drag brakes for the rear and will eventually have them for the front too.
Also, what is the pedal feel like with the manual master.
Thanks in advance,
Dave
Thanks in advance,
Dave
9-Second Club
Originally Posted by CanuckSS
Hi Guys,
Thanks in advance,
Dave
Thanks in advance,
Dave
Good luck, Ed
Originally Posted by Ls1Joe
and do you have to redrill the brake pedal.
Originally Posted by Hawkn01
I have the Strange manual master cylinder kit that Billingsley sells, and yes you should drill a new hole 1" higher than the stock location to give it a better angle of attack. If you don't the arm will have a downward slope and your leverage won't be as good.
Originally Posted by GM Muscle
How is it driving on the street with manual brakes?
After the manual master install they were much better, also saved weight. I highly recommend the manual master cylinder. Money well spent.
What is the bore diameter on your master Hawk01?
Thanks
Thanks
I'm willing to bet the Smith brothers deal (since your in Canada)is probably the same thing that Jay sells.
I have manual brakes. Using a factory manual master from a different car. With an adjustable proportioning valve. It stops just as quick as a power system. It just takes a little more pedal effort.
