Drag Racing Tech
How much gas do you run the 1/4 mile with??
Old 04-02-2006, 01:56 AM
02SS:ZEUS's Avatar
Default How much gas do you run the 1/4 mile with??
The last time I went to the track, I ran with under 1/4 tank of gas...because of weight. Someone told me that my car might actually run better with a full tank because of the weight on the back tires and the weight transfer. Is this true? Should I keep it under 1/4 tank? Please let me know, I'm headed back to the track tomorrow and am not sure if I should fill up.
Old 04-02-2006, 03:52 AM
Packy's Avatar
I usually run with about a 1/4 of a tank or so. I run with ET Streets so traction is pretty consistent for me. However when I used to run with Nitto DR's the more fuel I had the better my tires would stick.
Old 04-02-2006, 06:47 AM
Old Drag Racer
Smokinstorm's Avatar
I run with an 1/8th of a tank usually. Traction isn't a problem with my Hoosier Quick Time Pro's even though they're only 8" wide. My car slows down noticeably if I have a half a tank or more.
Old 04-03-2006, 06:09 AM
Demonicbird00's Avatar
1/8 tank here
-brandon
Old 04-03-2006, 03:26 PM
chrs1313's Avatar
Originally Posted by Demonicbird00
1/8 tank here
-brandon
still haven't run that car yet , go with a 1/4 tank so you dont have to fill up after 6 or so passes
Old 04-04-2006, 02:05 AM
anthonyz281999's Avatar
ya usually 1/8 here too
Old 04-04-2006, 03:01 PM
GregWS6&z28's Avatar
start 1/4, end at 1/8 tank
Old 04-04-2006, 03:16 PM
JRracing's Avatar
1/4 tank.
Old 04-04-2006, 04:03 PM
fuseone's Avatar
idk i find when i got a full tank its better because i get like no traction if its around 1/4
