Drag Racing Tech
Front mounted fuel cells. Bad idea?
Old 04-05-2006, 04:44 PM
DopeFedZ's Avatar
Default Front mounted fuel cells. Bad idea?
So I already have a fuel cell for my nitrous up front on the passenger side and now I want to install a 2-3 gallon cell on the opposite side for the motor alone. Is it a bad idea to have all this fluid in front on my tires? I guess it could get pretty ugly if gas started leaking out and getting under my tires going down the track.
I want to open up this hole on the driver side it mount it there just like I have the nitrous fuel cell on the passenger side
Old 04-05-2006, 04:56 PM
Outlaw's Avatar
NHRA tech people might have a problem with it. The cell is supposed to be within the frame rails and protected from any direct impact spot and protected by some sort of metal sheild incase something flys up off the track it does not have a direct path into the cell.
Now this is just what the NHRA tech's out here have told me.
Old 04-05-2006, 06:32 PM
The Bull
DERTY's Avatar
Technically it needs to have a piece of 1.25-.065 tubing around it regardless of where it is. Ideally within the frame rails. However, a large number of people (myself included) have put standalone fuel cells in that space and have never been questioned about it once.
Old 04-05-2006, 06:34 PM
DopeFedZ's Avatar
Thanks for the help guys. Techs down here in Houston aren't really that strict so I don't think they would hassle me if I put it there. I'll guess I'll just have to think about this a bit.
Old 04-05-2006, 08:13 PM
LS1Tech Sponsor
MADMAN's Avatar
IF you put a cell in the front and its a plastic one make sure you run a ground wire from the cap retainer bolt to the frame. That is the one thing that the tech inspectors are looking for. Otherwise I do reccommend Derty's idea. It is NHRA required.
__________________
www.madmanandcoracing.com
225-343-9029
Old 04-05-2006, 09:21 PM
skipperbisket's Avatar
Dope...the Icon formula from down there in Houston has the fuel cell mounted up in the nose from what i remember. maybe pm them and request some pics.
Old 04-09-2006, 07:40 PM
Sandmann120's Avatar
Does anybody else have any pics as to how they mounted thier fuel cells up front? I am looking to run one for my N2O system, adn would really like to get a visual on how to mount it.
Old 04-09-2006, 07:53 PM
my nitrous fuel cell is mounted where the battery was originally.
Old 04-09-2006, 08:04 PM
DopeFedZ's Avatar
Here is where mine is mounted. My friend kind of just bent up a bracket to go around it then we secured it to the car with self tapping screws. Nothing fancy but it served its purpose.
Old 04-09-2006, 09:00 PM
Thanks for the quick responses. Which fuel cell are you using? Jaz?
Old 04-09-2006, 09:17 PM
mine is basically just like dopefed's, i cut out the area where the battery was and just mounted the cell down there.
Old 04-09-2006, 09:38 PM
DopeFedZ's Avatar
Jaz one gallon cell.
Old 04-09-2006, 10:32 PM
FastBlackTA's Avatar
I've had mine up front for a few years...no issues.
https://ls1tech.com/forums/attachmen...chmentid=60620
Old 04-09-2006, 11:24 PM
fastblack, where do you have your coils mounted? that is one of the next projects i'm going to be taking care of and i'm looking at the options. thought about mounting them on the HVAC delete plate but looking for options.
Old 04-11-2006, 11:14 AM
chpmnsws6's Avatar
looks like the factory location, he just doesn't have them mounted... if you can tell by the coil plug
Quick Reply: Front mounted fuel cells. Bad idea?
