Drag Racing Tech
Pic's of my weight reduction
Old 04-07-2006, 11:37 AM
trigger1's Avatar
Default Pic's of my weight reduction
I haven't weighed everything I pulled, but I figure a fair amount of weight came out of the car...
Old 04-07-2006, 11:47 AM
11SECSS's Avatar
I would say around 75-100#'s from what I see go ahead and take those rear speakers out also.
Old 04-07-2006, 11:57 AM
trigger1's Avatar
Good deal. The pictures are somewhat dated (a few weeks ago I believe) The speakers are out now.
I am trying to offset some of the weight I will be adding (six point roll bar).
I also have swapped the stock rim's w/ MT ET radials setup for a set of 15x3.5 prostars with Moroso DS2's up front and a 15x10 prostar with an ET Drag out back. Removed front swaybar too.
Besides what you can see in the pictures and the wheels and swaybar I think that is going to be the extent of my weight reduction, I might add a set of Kirkey's or something although I don't know how much the savings will be over the stock non leather non power seats I have now.
Race your car!
JL ws-6's Avatar
How did you get the back panels out whre the side speakers are? I was planning on taking my car apart this sunday to remove al the stereo and carpet backing... haven't figured out how those come out yet though.
Old 04-07-2006, 12:01 PM
trigger1's Avatar
I can't remember off the top of my head. Let me take a peek at the car tonight after I get home from work and I will get back to you.
From what I can remember it was something like remove the little "clothes hanger" pieces and pull.
Old 04-07-2006, 12:05 PM
Race your car!
JL ws-6's Avatar
sounds good. I'm sure once I'm in there and start taking stuff apart, it won't be too bad. Where's the seat unbolt from too while your at it? I haven't even looked yet.
Old 04-07-2006, 12:10 PM
trigger1's Avatar
The fold down portion of the rear seat is just a nut and bolt on a pivoting little bracket, look towards the bottom rear on each side, it's very simple to remove, The bottom "buckets" are just a single bolt 13mm or 12mm if I remember correctly.
Honestly the interior comes apart very quick and easy just make sure you have a set of torx bits and a decent set of wrenches and sockets.
I have never taken anything but the center console and the seats out of the car and was able to do all that in way under an hour.
Old 04-07-2006, 12:13 PM
Race your car!
JL ws-6's Avatar
I've had the rear seat out for a while. I have tons of tools, torx, both the ones with teh nipple in the center and the ones without.. I should be fine. just curious if there was any problem area I should look out for.
Old 04-07-2006, 12:19 PM
trigger1's Avatar
Not a single problem or tricky area, everything was very straight forward. The biggest pita was driving around to find a decent torx bit set. 3 hardware stores, finally found what I needed at the third one.
Old 04-07-2006, 01:01 PM
DopeFedZ's Avatar
How about putting in a lightweight carpet?
Old 04-07-2006, 01:31 PM
trigger1's Avatar
I guess I could do that, but honestly I don't mind the "tin can." Carpet really isn't that big of a deal to me.
Old 04-07-2006, 02:19 PM
Race your car!
JL ws-6's Avatar
I was thinking about doing now myself... not sure if I will, but the backing it coming off the stock stuff at a minimum.
Old 04-07-2006, 04:10 PM
Bryan @ Speed Inc.'s Avatar
just pull it all out. dont' mess with cutting the backing out and trying to put it back in.
Old 04-07-2006, 05:21 PM
01Generalee's Avatar
You should get some weight off if you ditch your ABS and AC. I know those are two pretty common ones.
Old 04-07-2006, 05:42 PM
mvonada's Avatar
What did you do to pull the console - thanks for the pics also.
Old 04-07-2006, 06:46 PM
trigger1's Avatar
center console, there is a nice write up somewhere about installing a shifter, you can follow that and should have no problems. I believe it's at www.installuniversity.com
