Drag Racing Tech
bmr alt bracket
Old 04-13-2006, 06:37 AM
speedracerz's Avatar
Default bmr alt bracket
what belt to run with bmr alt bracket and a asp underdrive pulley ( pulley should not matter due to the amount of adjustment availible) ?
Old 04-13-2006, 06:44 AM
skipperbisket's Avatar
sorry for my ignorance but what does the bmr alt. bracket change? does it move the alt. somewhere else or is it just a lighter weight version of stock?
Old 04-13-2006, 08:18 AM
LS1TECH Sponsor
Steve Burger's Avatar
Not sure yet. I will be installing mine in the next week.
Old 04-13-2006, 08:25 AM
1STGEN68-2000SS's Avatar
We are running a Bando 4pk 790. You will not be able to find a 5pk belt that short so everyone runs a 4pk. Since you will have a extra groove on the pulleys we run the belt on the first grooves closest to the front of the pulley.
This will only apply to your car if you have no power steering or water pump.
We run alt only.
Alan
Old 04-13-2006, 09:31 AM
383ss's Avatar
I run a 3 rib. that is all I could find for a ribbed belt that short. just measure what you need and go to any auto parts and tell them what you need.
Old 04-13-2006, 10:02 AM
Thanks for the help
1stgen who sells the bando 4pk 790?
Old 04-13-2006, 01:00 PM
If you are running alt only you will be able to find that size in goodyear or gates also.
Alan
