Drag Racing Tech
Pinion Angle Question???
Old 04-22-2006, 10:32 PM
Jonezy's Avatar
Default Pinion Angle Question???
I have a chasis mounted adj. TA, so after several test passes my car was most consistant and pulling the best 60' with -3*. So I decided to add relocation brackets. I set the LCA in the middle hole and adj my TA to get -3*. Car was junk, rear end wanted to come up, had 0 weight transfer and a terrible 60*. So i put the TA at -2*, 60's were good and consistant but still a .10 off what my 60's were without the relocation brackets. So, what pinion angle do you use with relocation brackets? Thanks for the help. I am startng to think that my car may be better off without the relocation brackets. I will be taking my car to a TNT next friday to try and find the perfect spot but all input and help would be appreciated.
Old 04-23-2006, 03:23 AM
TheBlueGoose's Avatar
check that the rearend is not in a bind from the changes.
Old 04-23-2006, 03:39 AM
chpmnsws6's Avatar
To know if you the relocation brackets are working or to much, you need to know how hard the car is planting the tires
Old 04-23-2006, 01:41 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Are you adjusting the front mounting point of the TA (if yours is adjustable) up and down or at the rear? The reason I ask is that you may be changing the instant center drastically. I can't see the relocation brackets hurting you especially if they were close to parallel to the ground.
Keep us updated.
Old 04-23-2006, 07:30 PM
Mike Comp T/A #57's Avatar
Is your car lowered? Mine is lowered and I use the middle setting with no problems.
My pinion angle is - 2 degrees.
Old 04-23-2006, 09:07 PM
Jonezy's Avatar
what tires are you running and what air pressure? no my car is not lowered
