Drag Racing Tech
Burnout in an M6
Old 04-23-2006, 03:27 PM
ravensfan's Avatar
Default Burnout in an M6
I feel like a real newbie asking this, but how do you do a burnout in an M6? I dont have a line-lock ( and I know it will make it easy)
Any tips?
Old 04-23-2006, 03:38 PM
Slow00ls1T/a's Avatar
you rev the car up with ur right foot and left foot on the clutch dump the clutch and use your left foot to get onto the brake real quick real easy
Old 04-23-2006, 04:03 PM
SPEEDYws6's Avatar
Or if your foot is big enough you can hold the brake with your right heel and gas with your right toe, while using your left for the clutch. This method will keep the car straiter.
Old 04-23-2006, 04:39 PM
Packy's Avatar
Using second gear makes it easier too!
Old 04-23-2006, 05:45 PM
chpmnsws6's Avatar
and fries your clutch if its not 100%
Old 04-23-2006, 10:29 PM
Packy's Avatar
That is why you get a good aftermarket one!
Old 04-23-2006, 10:38 PM
chpmnsws6's Avatar
Man with deep pockets I see
Old 04-23-2006, 11:02 PM
Packy's Avatar
No, I have just never found what you said to be problem in the 5 years that I have owned my LS1. I have never heard anyone say that it was a problem either.
Old 04-23-2006, 11:44 PM
770Guy's Avatar
I agree, 2nd gear, 5grand, dump the clutch and just move your foot to the brake. The car wont move an inch.
Old 04-24-2006, 03:28 AM
JCurtin's Avatar
I gave up trying. Linelock, well worth the money. Must say its my best mod to date on the ws6. lol.
Old 04-24-2006, 03:34 AM
JMBLOWNWS6's Avatar
2nd gear. I also have a line lock
Old 04-24-2006, 07:03 AM
ravensfan's Avatar
Thanks everyone. Ill give it a try
Old 04-24-2006, 09:30 AM
Packy's Avatar
Hell yeah! It works like a charm! Heat the tires up good too!
Old 04-25-2006, 01:08 PM
Daredevil_TA's Avatar
i would have to agree with the above post about not doin it in 2nd gear, "that is if you have a STOCK clutch that is fairly wore down" trust me i found this out the hard way, stock ls1 clutches are junk, if you're gonna do it i suggest doing it in like a puddle of water or something, that way its a little easier on your tires, an you don't have to rev the engine up so high that you bounce off the rev limiter---(rev to like 3500 dump the clutch, get your tires spinning, then move your foot to the brake an apply firm pressure an work the gas keeping your RPM's around 4500 to 5000---smoke em as long as you like then ease off the brake pedal an lay a patch of smokey rubber
Old 04-27-2006, 10:28 AM
tboysen00's Avatar
^ couldnt have said it better myself
