Drag Racing Tech
How Much E/T is sway bar removal worth?
Old 04-23-2006, 05:39 PM
Camaro_Z28's Avatar
Default How Much E/T is sway bar removal worth?
Just curious How much time in the 1/4 I can gain from popping off the front swaybar. It's just on street tires at the moment. Thanx
Old 04-23-2006, 05:46 PM
blind527's Avatar
Some guys report anywhere from .100-.200 depending on conditions.
Old 04-23-2006, 06:00 PM
you2slo's Avatar
Plus 12lb weight savings.
Old 04-23-2006, 06:06 PM
Camaro_Z28's Avatar
I've heard that it gets better results with drag radials, is that true?
Old 04-23-2006, 06:53 PM
hashtagBMW
Speed Density's Avatar
It unlocks the front end. The whole point is to better transfer the wieght to the back. And with the front end being disconnected the car is more able to do that.
Tony.
Old 04-24-2006, 08:24 PM
blind527's Avatar
Mine measured in at 16 pounds with all the brackets.
Old 04-25-2006, 03:40 PM
Hambone 7's Avatar
that and drag shocks and you'll pick up a bit.
Old 04-25-2006, 04:18 PM
blind527's Avatar
You'll get better results with DR's regardless.
The sway bar removal will help a bit. That's why I'm hoping for 12's.
Old 04-25-2006, 08:13 PM
RGR Pete's Avatar
Here's my predication 0... gave me a tad worse 60'.
Old 04-26-2006, 08:43 PM
LFTNWHLS's Avatar
The rule of dragracing is how much money you have is how fast you will go.
Just get your wallet out and it's easy.
That's why I am stuck in the 11's I had to put my wallet back in my pocket.
Old 04-27-2006, 07:51 PM
Camaro_Z28's Avatar
HAHA, No joke, Mine always stays in my pocket or I will "over-utilize it" Its bad enough making the car and insurance payment, let alone think about all the options I have to make it run 10s, but knowing that in real life I can never afford them.
Old 04-30-2006, 02:31 PM
ls2 bait's Avatar
so if you disconnect this and you run a stb you will need to remove that also im assuming as that would still be connecting the front end.
