Drag Racing Tech
launching off a 100 shot
Old 06-19-2006, 09:13 PM
smokin2002's Avatar
Default launching off a 100 shot
My car is 2002 TA Cam only with a yank 4400. I have most every suspension mod less the Rear drag drag bar, and relocation brackets that will be on tommorow. I first ran the juice first time last friday and had no such luck hooking. on motor i cut 1.5 60's all day. but with n20 it hooks then slings the *** end out everytime. 1.7-1.9 60's spinning. Best run on n20 was 11.7 at 119 mph, motor was 11.9 at 110 I picked up almost 10mph on and off the juice due to 1st-2nd shift n20 is not liking that 4400 stall. tagged limiter hard... I know idealy i should step down the converter but i dont have the biggest chunk of change to play with at the moment. Is there anything im greatly overlooking??
Bmr adj torque arm
Bmr tubular adj control arms
TA panhard
Bmr boxed subframes
QA1's all the way around with 275 springs
12 bolt 4.10s
weld - 26x11.5 MT wrinkle walls
Batt relocation
Relocation brackets - tommorow
Wolfe Rear drag sway - soon
It just seems my car is suffering bad from body roll and the xtra power may be unloading the left wheel now.. all in all i need a 1.5 or hopefully a 1.4 60' to make anything respectable from 120mph traps!! I tried to tighten the right rear shock a few clicks from loosest setting... makes my car wheel hop and jump up and down in wet box and not transfer any weight on the launch!!! over 10 more clicks after that!! I dont get those shocks i can ony run them all the way loose or 2 clicks.
