Drag Racing Tech
gutting now in process, *pics inside*
Old 06-20-2006, 10:05 PM
Taubr Unit's Avatar
Default gutting now in process, *pics inside*
Heres the dash pulled and everything gone w/ heater core blocked off w/ aluminum sheet. Any advise from the pros on anything else to do while im at this point before it goes back toghter?? in the mean time, heres some pics........
Old 06-20-2006, 10:56 PM
Demonicbird00's Avatar
dam im not that ballsy yet.
looks good tho, what was the amount of weight that you took out?
-brandon
Old 06-20-2006, 11:16 PM
SScam68's Avatar
Good deal.
I'm about to do this myself.
Are there any tips you care to give on pulling the dash? Were you able to pull it without breaking anything?
Old 06-20-2006, 11:26 PM
kp
kp's Avatar
dont forget to scrape that sound deadening stuff off the top of the dash.
Old 06-20-2006, 11:33 PM
Taubr Unit's Avatar
dang, id figure someone would say that. Thats the only thing i didnt do. seems like a real pain to get off too. As for weight, i work at a bicycle shop and i filled a bike box (about 3ft. high, 1ft wide, 5ft long) filled it to the MAX and buldged the box too. Id say at least 100lbs for sure. And the pass. air bag weighs a ton also. Who would have thought it weighed that much. It went pretty easy with 2 people (must!) and the only piece i broke was the upper dash piece that goes all the way to the window w/ the defroster vent in it. The tabs were REALLY tight holding it to the dash and i cracked a little piece off the corner tryin to pry it off. Other then that its not as bad as people say. And now with 90% of everything gone im sure puttin it back on will be a piece of cake!!
Old 06-20-2006, 11:35 PM
Taubr Unit's Avatar
heres what i went by, it was posted by another member on here, i printed it out and went by it and it was pretty straight foward:
Disconnect the battery.
Remove the E brake handle, shifter **** and console. drop the steering column from the metal brace its attatched to( remove the safety brakt too). Unbolt the steering column from the firewall. Remove A-pillar trim. Remove upper dash piece (the one with the defroster vent). Remove the speedo trim (pull firmly), Remove the speedo cluster, 4 bolts then pull firmly. Remove the stereo HVAC trim panel (pull firmly) unbolt the radio and the HVAC control panel. Remove the vaccume lines from the HVAC control panel. Remove the kick panel trim. Remove the nuts on the ground studs on the passnger and drvr side. Disconnect the wires to the pssngr side airbag, the ABS computer etc. Remove all of the srews along the top of the dash that were under the upper dash panel. Remove the bolt at the bottom of the dash, in the center, behind were the HVAC controls were (it's bolted to the tunnel). Remove the wiring that is clipped to the dash. Then pull dash forward. You may also need to unbolt the vents from the back of the dash.
Should take 2-3 hours.
Old 06-20-2006, 11:41 PM
Taubr Unit's Avatar
heres a few more pics, front and rear bumper supports off, deleted egr, air cond, heat, smog, ps, battery etc.
Old 06-21-2006, 10:37 AM
LC
LC's Avatar
Is that really heavy? because it's not moving on my car, glued to death...
Old 06-21-2006, 10:42 AM
kp
kp's Avatar
Couple pounds, a sharpened putty knife gets it off, just takes a little time. Same stuff in in the T-top well. If you are there and you are taking weight out you may as well get it all. Remember 1 lb out of 10 places equals 10lbs, it alll adds up..
Old 06-21-2006, 12:21 PM
The Juggernaut's Avatar
I used a heat gun and a putty knife, wasn't that bad.
Old 06-21-2006, 02:28 PM
GuitsBoy's Avatar
DOnt put the dash back, and just cut out all those wires
Old 06-21-2006, 11:15 PM
phoenix's Avatar
roll cage
Old 06-22-2006, 01:03 AM
Taubr Unit's Avatar
ok, took off the stuff on the dash tonight, anything else or am i all good now
Old 06-22-2006, 10:09 AM
11SECSS's Avatar
If you dont have a heat gun borrow someones blowdryer it will work the same and remove the wires you wont be needing like the radio stuff ,heater controls,etc.
Old 06-22-2006, 12:55 PM
Taubr Unit's Avatar
i didnt use a heat gun, just get ureself a 4'' puddy knife and go to town!! Only took me bout a half hour. So now comes making aluminum templates for the heater controls etc.
Quick Reply: gutting now in process, *pics inside*
