ET Streets fitment
That's the smallest wheel that you should use on that tire. I see guys stuffing them on smaller wheels, but they shouldn't be doing that. Actually, a larger wheel will give better results and performance with your tires but what you have currrently will work.
The tire will stick out a bit since the backspace of your wheel is not correct for a typical F-body rear-end. Our Bogarts are the only drag wheel from majory manufactures that has a large enough backspace if a customer wanted to go with a smaller wheel like you have. I rarely (can count litterally less then 5 folks ever who have demanded a smaller wheel for an F-body setup).
Good luck:-)
Good luck:-)
