How Low is to Low on the front end?
With the front lowered, with Qa1's set to 2 and 300 lb springs, how low is to low? If the front lifts how much room does it need not to cause any problems? The problem isnt on the way up its obviously on the way down.. or am i thinking to much and it wont be a issue.. I am running skinnies up front and they barley clear the fenders, should i add more ride height?
I borrowed this pictures as a example.. my car sits higher then this one does.. would this car have problems?
Is yours the stock ride height? Im not really sure whats its going to do with the new setup.. Its always hooked well and settled down before the 60 ft.. not really wanting major wheel stands but it lifts out of the hole just enough to clear the fronts..
Originally Posted by SMOKIN01TA
my springs are adjusted a lil lower than stock but not alot
