Launching an M6 with DR's??
I feel stupid even asking this, but what RPM would yall recommend for a basically stock LS1, T56 on BFG 16in DR's? Im thinkin 2500-3000k. Any advise would be appreciated.
are you on stock clutch and rear? do you have headers?
on stock clutch w/ stock manifolds go from 3500 and slip the clutch, dont dump it or youll break the rear.
on stock clutch w/ headers, slip the clutch from 4500 and go.
hope that helps
-brandon
hope that helps
-brandon
hope that helps
-brandon
hope that helps
-brandon
If your serious about running your car at the track I would start saving for a rear or don't get too greedy at the track and launch the car on the soft side. I snapped a axel on my stock rear with 4.10 gears with just bolt-on's with less than 1,500 miles on the car. The stock rear with a m6 and a sticky tire can be broke pretty easy if your not carefull
Originally Posted by LawHorn
I have a ram vds clutch and hooker LT's. I have 18x10 TTII's so is 3500 a good launch?
as long as he slips the clutch out and works the launches that way he'll be fine
-brandon
yeah if your on street tires.
-brandon
-brandon
Originally Posted by aaronbetzner
Not to hijack but what about TSP cam 12 bolt 410's and headers and bfdr's? Stock clutch.
arron.....i had your setup minus the cam and was going from 4500 on my stock internal car. on stock clutch you have to slip it. cause the stockers cant handle dumps.
-brandon
-brandon
But at the same time slipping the stock clutch will hurt it just as fast, you are causing a lot of heat when you are slipping the clutch. My stock clutch last about 6 track passes of 1.8 60fts with stock internals and then it was shot. Also make sure it does not dead hook from 4500 otherwise say bye bye to your 10bolt.
