Drag Racing Tech
Guys with roll cages and carpet come on in
Old 08-04-2006, 01:01 PM
FASTFATBOY's Avatar
Default Guys with roll cages and carpet come on in
What is the best way to get the carpet to fit around the bars? Procedure for cutting and fitting. Pics if ya got em.
David
Old 08-05-2006, 04:46 PM
tektrans's Avatar
Just gotta fit it up to the bar and cut a little at a time till it forms around it. I did an ok job on mine, seen better, seen worse.
Just take your time and make sure you use a fresh blade to make the cuts easier, good luck.
Old 08-10-2006, 06:38 PM
boondiggys's Avatar
i got the carpet all in the center of the car, with the seat bolts lined up....pushed carpet up under the dash and basically everywhere i could fit it...after everything was as far as i could go i started cutting the carpet in the center of the bar...cut a straight line towards the center of the car untill the carpet by your feet lies flat...a sharp blade does help when your rounding out your cuts
Old 08-10-2006, 08:20 PM
jshiver's Avatar
where do you get the lightweight carpet?
Old 08-10-2006, 08:35 PM
LS1Tech Sponsor
Brady's Avatar
Speed Inc.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 08-10-2006, 08:37 PM
LS1Tech Sponsor
Brady's Avatar
And off topic, but here's the link to your other question Jason: http://teamprickracing.com/95z/bigtires/
No template, just eyeball it
__________________
2016 Z07 Carbon
Old 08-10-2006, 09:20 PM
SSPerformance's Avatar
Originally Posted by Brady
it shows the carpet N/a
Old 08-11-2006, 04:05 AM
cry-baby buyer
BLO BY U - TA's Avatar
I saw the same! Anyone call them?
Alan
Old 08-11-2006, 06:08 AM
Blown408's Avatar
They do not sell it anymore due to a change in the way it was made from their supplier. It was not really "light weight" anymore.
Old 08-11-2006, 07:19 AM
tektrans's Avatar
I got mine from Year One.
Old 08-11-2006, 01:20 PM
jshiver's Avatar
Thanks Brady..I appreciate it
Old 08-11-2006, 01:35 PM
FASTFATBOY's Avatar
I did it, I just cut down the bar to the floor, split it around the bar and cut two 1/2 moons out on each side, turned out ok.
David
Old 08-11-2006, 02:05 PM
SiL3NtXWS6's Avatar
Old 08-11-2006, 06:15 PM
msb184's Avatar
Smile Tool
I put a 6'' piece of 4130 1.75 in tubing in the lathe & cut a sharp angle on the inside edge of the tubing. Makes a very sharp edged round punch. Worked great. Since then I've made several sized punches for other things. If it gets dull it's a snap to cut a new sharp inside edge.After you cut the hole Lay the carpet & pull it up to Tig your cage tubing to the car . Pull the carpet down & no carpet cut or raggy edge. I will make my next punch a little bigger for this purpose next time ,easier to slide up the carpet to weld. Everybody that does any Chassis work has got a barrel of "cut off's" because nobody throws 4130 Chrome Moly away. $$$
Old 08-11-2006, 06:34 PM
skipperbisket's Avatar
i'm about to have to put carpet in my car with custom 12 point, through the floors and kirkeys and i'm half tempted to just take it to an upholstry shop and have them do it. looks like a pain in the ***
Quick Reply: Guys with roll cages and carpet come on in
