ET Drags Question
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
This is a question that will always be asked over time.
Tubes add weight but a touch of safety as well.
I don't run them b/c my slicks don't rotate on the rims. Usually when someone runs rim screws the tires will leak, thus adding tubes will solve that problem. Most 10-11 second racers I know don't run tubes, but everyone is different.
Derek
Derek
We do not use tubes. If you decide to run tubes I would use a screw kit. When you put tubes in and the tires spin on the wheel they will tear the valve stems off the tube.
Alan
Alan
CARTEK Racing
I don't use tuber either... I usualy run 11.5 to 10.0 PSI in my 28x10.5 15's Never had a major problem. They don't hold air for long, but enough for one day's racing.
I have also seen ET Drags screwd to the rim, w/o tubes. They held air just fine as well.
Cool, thanks guys. My ET Streets are screwed to the rims right now tubeless, so thats whats going to happen with the slicks too. I came home from work today and there they were on the porch waiting for me
