Is 1000cfm big enough to support 600-625 NA hp???
Not RWHP but flywheel HP..... expecting motor to make somewhere in this area hp wise... using a victor "E" manifold, AFR 227's, large solid roller nitrous cam, lunati crank, JE pistons, Oliver rods, 12.5:1 compression....
Here's what I intended to use on top of the victor "E"...
It's rated at 1000cfm but I'm hoping that that is enough airflow to support the power i'm trying to make.. i don't want to buy something that is a restriction.. i know most go with elbow's and single 90mm TB's but i'm trying to avoid that....
7 Second Club
Originally Posted by MADMAN
Are we talking rear wheel or flywheel. My sbc made 698 flywheel with a 1000. I had it modified to 1300 and it picked up 25 flywheel. I then went to a 2000 and I made 765 flywheel. I am a firm believer in bigger is better on a throttle body.
So madman, is it true that you can't over-throttle body an EFI motor with a standalone engine management system (FAST XFI on mine)?????
Cuz I've heard nightmares about carb guys that are running a carb way too big and have nothing but driveability and tuneability problems.... cause hell i'll slap the 2000cfm accufab on there and call it a day if that's the case..... same price so it's worth it for me....
Originally Posted by OutlawZ
I was talking Flywheel HP.... We are going to make the big power with the nitrous (400 hit) so I'm talking NA power at the crank....
Nate
I have kept this place a secret for a while........If anybody else is looking for one heres the link. This is where I bought mine.
http://www.yourperformancesource.com...PROD&ProdID=79
