Which springs for my drag car?
when you cut the coil off them, did you heat the springs so you could get them back flat on the last coil? I had a car come in before with cut springs in the rear and the springs werent seating very well due to them not having a flat coil on the top anymore
6 & 8 Second Club
We cut them flat with a long blade on a saw zall, clamp it down, and cut on an angle. We've done it 3-4 times, no problems. All on old chevys, I have no knowledge about new cars, sorry.
I removed the stock isolator, cut a coil out and lined the top with some heater hose. Dropped the car about 2-2.5 inches I'm guessing and seemed to work well. With the stock cut springs and my Hals set on level 10 in the rear, I could still cut 1.3x sixties on slicks and 1.6x's on 17" drag radials. The car has virtually zero squat.
Originally Posted by calongo_SS
Doesn't cutting the spring change the spring rate?
I was considering removing the isolator and wrapping the top coil w/ some rubbre hose or something but didn't think it would be worth the effort.
