Launching in 2nd?
Launching in 2nd?
as we all know one of the biggest problems with the fbodies is getting traction. a friend of mine claims that if i launch the car in second i won't spin outta the hole. after that he says to drop it into first to gain speed and then go to drive. i can understand is rationality with not spinning, but i get the strong feeling this would screw up my E/T. so recap: launch out of second, drop into first, and then go to drive. he claims that i will get better times, but to me it sounds like a load of crap and too much work that gets little results. anyone ever tried this and should i stick to keepin it in drive? by the way i'm still on street tires. thnx.
1) Go punch your friend
2) Traction is not a major problem. Go buy a set of sticky tires.
I guess my consistent 1.5 60' times are traction limited.
suspension and good tires, no replacement for em, ive watched the 6 speed guys launch at 4500 or so on mt ET street radials with suspension similar to mine and cut 1.5 and 1.6 60' that are puttin down a good amount of power, not some kinda 4-link or ladder bar set up that requires a ton of work just basic bolt on suspension from spohn/umi/bmr
Originally Posted by WheelsUp84z
umm in an automatic, it doesnt matter where you put it..it doesnt actually launch in 2nd gear, and with that much of a stock car...you'd probably see the same results if not better leaving it in drive instead of manually shifting
A 4L60E starts in 2nd if manually selected. Many other trannies do also.
We do that with the manual cars when they are on street tires or the track is just crap and we dont want to pack up and go home. but for an Auto car, that is just dumb much less pretty hard to do....
That works, but you may try doing it slightly different. First, leave it in drive or OD and instead of moving the selector from 2nd back to first ... do not put the accelerator to the floor. Gradually depress the accelerator down, while being on the edge of tire spin. Instant better launches without breaking the transmission. Which will result if you listen to your friend. Autos do not like that (shifting from 2nd down to first, up to 3rd) being done to them under WOT.
You also could try holding the break with your left and give it 1K rpm's just to load the drivetrain while keeping the above method the same. Sometimes this way takes some of the initial shock out of the tires.
....Oh yeah, and your friend is an idiot.
Originally Posted by 01_ram-air
+1, if you put the car in 2nd, it will be in 2nd.
However, if you put the car in 3rd (which is D for a Camaro), the car will start in 1st.
Originally Posted by aaron653
weird my car starts off in first no matter what. if the selector is in second, it starts in first and will only shift to second.
