What gear are you 3speed guys running?
What gears are you guys running with a th350/400 setup? I have 3.50 in the rear with 28s. I was wondering if I am leaving too much on the table. My the best 60' I have had is a 1.52. That was on the spray. 4000rpm converter
n2o,
i'm the same as you. TH350, 28x11.5 QTP's that are 3years old, 3.50 rear gears. Off the footbrake and a 100 shot, it'll do mid 1.4's.
I have QA1's all the way around, 2 up front and 5 in the rears, wolfe solid rear drag sway bar, Spohn trans mount torque arm(relocated to the BMR crossmember)
I am trying this again this week. Car was not running in tip top form the last outing. If it doesn't go in the 1.4's I will be changing some stuff. I just installed a k-member also.
TH400 with 4.30's and 28's
TH400 with 4.30's and 30's
TH400 with 4.11's and 30's
In the end I favored the 4.11's for a little extra room up top on the bottle, but still enough gear to get out decent NA on some drag radials. All those combos would cut 1.3-1.4's on the bottle though.
