What safety stuff is needed for running 9sec. et's
I plan on having most of those things, besides the NHRA or IHRA license. What happens when you consistantly run in the 10's and you break over to the 9's even just a 9.99 run? Reason is I hope to run in the mid to low 10's and hopefully get a single didget run in oneday. Do I need to get the license before hand or afterwards to keep running?
6 & 8 Second Club
Depends on track, some actually put your max time on their computer.
I ran 9.98 at RT 66 and they threw me out. I was dialing up to 10.00.
The problem is you need to run the number to get the license, so if your car only runs 9.90's in great weather it's hard to know what u will run the day you try to get it.
My buddy ran 9.95-10.10 and every time we tried to get license, the Alt was too high.
Good luck.
Good luck.
I'm pretty sure the chute is just for 150 MPH and over.
Depends on what track you run as to how much you can get away with. I went to an IHRA track that isn't very picky and ran 5.90's all weekend long without a neck brace, license or window net up (dumb, I know). Last weekend I ran a NHRA track with no NHRA license and no neck brace... Tech guy didn't even check anything, just signed off and let me go. Then again it was only 1/8 mile and a 5K bracket race so maybe they didn't care as much because my dad was almost kicked out of the same place a few years ago for running a 9.999. I wouldn't doubt them being more in depth during test n tunes.
With all that said, I wouldn't recommend trying to sneak through tech... It's not fun and it's 10X easier (and most importantly safer) to just have everything current and to the right specs.
Originally Posted by 94z28L
k got the helmet but a little help on the safety loop?
Thats Driveshaft Safety loop.
Originally Posted by ls1408cp
so how do I get a car certified and get my license
As far as a license, you need to contact the track set an appointment, do 3 runs with at least one of them being a sub 9.99 pass, cockpit orientation test, etc. They will let you know exactly what needs to be done for the license but the above stuff should get you the jist of it.
The rulebook says any car running non-slicks 11.49 and faster must have loop. Any car on slicks going faster than 13.49 must have a loop.
Not in those exact words, but the same definition
Download the physical and license forms from NHRA's website and go to your family doctor and have a physical done. Bring that to a local NHRA track (1/8 mile will work if you need to) and talk to one of the guys in the tower on a T&T night and let them know you want to make some license passes and most of the time they will help you from there with finding a couple drivers to sign off, make a couple easy passes and a couple full passes and mail everything in, along with your 2 years NHRA membership dues of course, and in a week or two you will have a license.
I waited until a local NHRA 1/8 mile track here had chassis inspections and got my cage certified and made all my license passes in one afternoon so its not that hard to do. In reality most people wont need either, depends on the track(s) you run at and the type of events you run in Common sense should really be the most important piece of safety equipment you posess. But if you ever want to run in a bigger event at a nicer track that stuff gets checked often.
If you run IHRA tracks you dont need the chassis certified to 9.50 I believe but you still a cage and license at 9.99 or quicker.
