Replacement Light Weight Spindles
Originally Posted by MADMAN
AJE offers a spindle for these car and so does Santhuff. Both require custom upper and lower control arms.
Originally Posted by Hawkn01
No, Strange doesn't supply a new spindle. You have to modify the stock factory spindle (Cut caliper bolt holes off and grind down so they clear new caliper)
FYI, I was told by someone at AJE that you can NOT use strange drag brakes with their spindles. This was for my 3rd gen, I don't know if the same applies for 4th gens.
Hey Slickvert, here are some pics of my set-up, I got all of this through AJE, I was/am very happy with the quality and performance this front end gave me. I dropped nearly 300LB's with just this front, skinnies, an EWP and removal of power steering.
Lower A-arm
K-member
Spindle assembly outside of car
Upper mount
All together!
Hope this helps man, good luck with your build
Lower A-arm
K-member
Upper mount
All together!
Race your car!
only problem with that setup is that it's not legal for alot fo classes.. but I do agree for a drag only car it is probably the best way to go. Sounds like just swapping to that front end with a manual steeering rack is a 275 lb weight saving.. awesome! I ever get really hardcore with my car, I'd put that on if whatever class I'm runnign allows it, sounds like that alone would get me down to where I want to be weight wise, with the bumper supports and all still in the car
Im pretty sure you cant do anything lighter in the front, this is why I went this route.
The quality is top notch and I am very happy with it. You wouldnt be disapointed with it!!
