Those with True Duals hows clearance loading on a car hauler?
Hows the clearance going up and down a dovetail carhauler with True Duals? I need to know before I get them done thanks?
my trailer is open in the center , no problems going on or off but not sure if you have a solid floor. I think you will have more issues not getting your front bumper cover to hit rather than the true duals. I have to use boards on my ramps to get the nose up enough so it doesn't hit going on and off
My trailer is flat with no rear slope and I can load mine without hitting but it is very close. about 2 inches of clearance. I built my TD's and they fit as good and maybe better than my old Borla fit.
I have tsp td and I have a simular trailer. they will rub if I dont put some wood runners to drive on to get it up high enough to clear.
I had mufflers off right off the headers and never had a problem but with the xpipe it is. I plan on going back to right off the collector before racing starts back.
my buddys hawk is SLAMMED and he has true duals(that scrape everywhere) and i believe he has the stands for the rear of the trailer that prevent it from dropping when u load the car, and I believe that does the trick..
Because I know lots of cars bottom out on the trailer when u get to the point where the beaver tail and the ramp start sag towards the ground.
