Drag Racing Tech
Billingsley Manual brake kit ?
Old 12-08-2006, 07:23 PM
Tim King's Avatar
Default Billingsley Manual brake kit ?
I just ordered this and was wondering if a proportioning valve is suppose to be used with it. I would think so but I would also have thought they would sell one if it was needed to complete the kit?
Old 12-08-2006, 07:34 PM
FASTEST ALL MOTOR LS1 IN THE COUNTRY
CAMN HAWK's Avatar
no valve is needed. it works fine without one.
Old 12-08-2006, 07:44 PM
Tim King's Avatar
Thanks
Old 12-09-2006, 09:19 AM
LS1TECH Sponsor
Steve Burger's Avatar
I am not using one either. The master is set up so that it is not needed. I am still using the factory brakes. Will be swapping to Strange brakes over the winter.
Old 12-09-2006, 09:21 AM
Tim King's Avatar
Yeah, that's what I was wondering. I have Aerospace on all 4 and wasn't sure.
Old 12-09-2006, 11:33 AM
Hawkn01's Avatar
I have the Strange drag brakes on all four corners with the manual master cylinder and no porportioning valve. They work great and save a ton of weight.
Old 12-09-2006, 11:40 AM
DMH Fabrication's Avatar
you dont need a proportioning valve unless your running lightweight brakes on the front or rear with stock on the opposite. If you have all stock or all aftermarket then your fine.
