vacuum reservoir for my brakes?
After the 408 went in the the BIG cam, i dont have enough vacuum to operate the brakes with the Auto transmission. I was just wondering if anyone else uses a vacuum reservoir to fix this problem?
thanks
chris
thanks
chris
You could use one of those vacuum resevoirs, I never used one on an LS1 car but have used them on a few others with large solid rollers. In the long run switching to manual brakes would probably be the best option though, that way you take off weight and extra parts instead of adding
One of those reseviors will help then and will be the easiest thing to do, has to be a pretty big cam since my old 414 with a 268/276 @ .050 on a 108 LSA still worked the power brakes just fine
