Anyone have a problem with car going sideways while doing burnout?
When I do my burnout with my line lock the car always seems to go sideways forcing me to let out and take a very short burnout. I've thought about just staying in it but I don't really like facing the wall when I come out of the burnout in fear of catching and going straight into it. Any trick to getting the car to stay straight? At first I thought maybe it was a susspension thing but I don't think so because the car launches perfectly straight. Any ideas?
Is it going HARD to one side?
Check your drag radials and make sure they are wearing similar. Also check your tire pressure.
I had a set of DRs on a car and it would go HARD left....The left side tire was more worn then the left...put a new set on there and it never did it agian.
Just a thought...
Just a thought...
Hmm, With a M6 in the car mine would do it when power braking(no heel-toe, just dump & grab brake), using the line lock instead of the foot brake cured it for me.
I never had the problem when the car was equipped with the stock automatic burning out on the foot brake. We'll see what it does with a TH400, 4000 stall, and line lock real soon.
Maybe something with the diff?
The rears a spooled 12 bolt. The susspension is pretty stiff, LCAs, relocation brackets, extreme torque arm, extreme anti roll bar and QA1s set at 5. The tires seem to be wearing evenly but it does pull hard to the left, only on the burnout, so maybe I should take a better look. The tires are hoosier QTP's so it's kinda hard to tell. Thanks for the help so far.
Race your car!
Try getting the tire speed up quicker, most of the time when I see a car do that, it's because they aren't getting the tires spinning fast enough or they take too long to get them up to speed. Just lay into it harder in the burnout box next time, see if that helps at all.
6 & 8 Second Club
My slow car did the exact same thing. When spraying at the crappy track in Ind. we tried putting rubber across the line. The problem was, the car needed pre-load to hook. I could never get it to stay straight. I quess it's rare, but some cars just can't keep it straight. It stayed perfect if I stayed behind the line 10-20 footers. I've never heard anything as bad as yours. Is everything square, maybe something is a touch off.
Good luck.
Good luck.
Mine isn't bad when sitting still, if it starts going left when I start on the throttle I always shift right into 2nd anyway (PG). My problem is mine always drifts to the left when I'm running it out of the box, sometimes it'll do it so bad I end up lining up out of the groove and my car will jump right. Mine might actually be suspension though.
wheel speed up faster....both fbodies i've driven at the track tried the same thing on a slower burnout, but once i noticed what it was i figured out the trick, never had a problem again. just click the line lock, and NAIL it...
1 Post
