Drag Racing Tech
breaker switch
Old 12-31-2006, 04:37 AM
93_z28's Avatar
Default breaker switch
im runing a 50 amp breaker instead of a fues on my power wire from my battery to my distribution block.do you guys think 50 amps is to small?i was useing an 80 amp fues before but i ran out of fueses and desided to use a breaker instead.
Old 12-31-2006, 09:59 AM
TS6
TS6's Avatar
Its gotta be way too small. I ran a 125 amp one on my GN and even tripped it once or twice.
Old 12-31-2006, 03:06 PM
93_z28's Avatar
where did you find the 125 amp breaker at?
Old 12-31-2006, 03:16 PM
Resident Racing Jerk
vtec's Avatar
i was running my car's power through a 60 amp fuse at one point. fuse was in the rear beside the battery, and i had a ford solenoid rigged up so that when i cranked the car the solenoid bypassed the fuse.
worked like a charm, but i never used all the accessories at the same time.
Old 12-31-2006, 04:18 PM
TS6
TS6's Avatar
Car stereo place. I originally used a fuse block, but blew a 125 amp fuse one day and realized those fuses were like $40 each, so I said **** that and installed the breaker. It was also nice because I could just hit the test button and open the fuse to disconnect the battery.
Old 12-31-2006, 08:19 PM
93_z28's Avatar
thanks,ill check out car stereo places tomorow
