Drag Racing Tech
Manual Trans and MT ET Street Radials
Old 01-19-2007, 10:16 AM
NastySSoo's Avatar
Default Manual Trans and MT ET Street Radials
Anyone using these tires with a manual trans? If so do they work well for you at the track. I know they are a great tire, but does the sidewall of these tires give enough to use with a manual tranny. I use an iron disc clutch and launch around 5,500. Racers please chime in!
Paul
Old 01-19-2007, 12:22 PM
NastySSoo's Avatar
ttt please
Old 01-19-2007, 12:33 PM
Gary Z's Avatar
Bias-ply ET Streets work much better with a manual transmission than radials.
Old 01-19-2007, 12:56 PM
NastySSoo's Avatar
Thats what I've always used, just trying to avoid the tire change at the track! Thanks for your input.
Old 01-19-2007, 07:56 PM
93camaro_zzz's Avatar
Im wondering this same thing. I am looking to purchasr the dr's pretty soon. I was wondering if a manual would shock the tire and just make it spin, since no sidewall flex.
Old 01-19-2007, 07:59 PM
rickssz's Avatar
My drag radials spin forever floored. They tell me to slip the clutch or mod the suspension.
Old 01-20-2007, 02:17 AM
prostock_bigblock's Avatar
Couldn't do beter than 2.0 60' with them, M/T recommand them on auto cars as far as I know.
Old 01-20-2007, 06:28 AM
TOSTO RACING's Avatar
Drag radials and stick cars don't work. Stick with slicks and get the Stiff sidewall.
Old 01-20-2007, 06:30 AM
sickss228's Avatar
For a MN6 you will want a bias ply slick. The stiff sidewall construction of the radial will not absorb the shock well when you dump the clutch, resulting in tire spin. On the other hand I did pull 1.7's 60' with 275/40-17 Nittos. I had to launch the car alot lower than I did with a slick.
Old 01-20-2007, 08:25 AM
gator's 99TA's Avatar
the only way they work is if you slip the **** out of the clutch. you will end up crushing the clutch fast. go with bias ply slicks.
Old 01-20-2007, 12:31 PM
Demonicbird00's Avatar
i used them on my best run in sig. i went 1.53 and a 1.55 60'. im lowered and im on stock tranny, i do have an adj TQ arm tho.
i love them, these were done w/ 18psi in the tires
-brandon
i was launching at 5k still getting used to the cam only setup, ive been to the track twice and have 5 passes total cam only
Old 01-20-2007, 12:55 PM
rickssz's Avatar
Brandon M6 5k launch with a stock suspension except torque arm on ET radial netting a 1.55 60'? Can you describe your launch technique for me.
Old 01-20-2007, 01:09 PM
im sorry i shoulda been more specific, im on DMS suspension(springs,LCAs,relocation brackets,SFCs,ADj PHR)(lowered) and tokico shocks.
i launch different from other ppl, as the lights come down on the tree i rev higher and higher. ie 1st yellow rev to 3k, 2nd light rev to 4k and 3rd i rev to 5k and slip just a hair/dump the clutch lemme see if i can find video of a launch.
-brandon
Old 01-20-2007, 01:18 PM
http://media.putfile.com/Brandon-vs-Rob sometimes it works and sometimes it doesnt, i was babying it due to the stock TA being cracked and bent lol.
but you get the idea of how i launch, i dont just go up to 5k and hold it.
Old 01-20-2007, 01:33 PM
SiL3NtXWS6's Avatar
I went 1.7 on 17" bfg DRs and i hope to cut 1.5's on 325 MT DRs.
i have almost everything there is suspension/chassis wise...
Old 01-20-2007, 01:57 PM
why in the world are you going to a 325????? thats way over kill. my street tires are 295s, but my MT DRs are 255/50/16 and thats plenty of traction. not to mention youll have more rotating mass cause of the bigger tires
Old 01-20-2007, 03:11 PM
STL2SLO's Avatar
I have not problems using them on my car leaving at 6500..
Old 01-20-2007, 03:54 PM
SiL3NtXWS6's Avatar
First off, my car is mostly a street car. I needed a tire that could hook a lot of power while still being able to drive distances and not get super worn down.
I've had the 325s for a while and they are just fine. I make 700-800whp and they are the only thing that can hold that kind of power from a roll. Plus, i like the look and my car is light enough to where i could really care less about added weight from the tires.
Old 01-20-2007, 04:22 PM
mike c.'s Avatar
just get some slicks! i cut 1.42 60's on motor(last year,i will be 1.3's this year) m6 car w/4.11's. i've tried m/t tires, drags and streets and for me they did not hook well. i run m&h racemaster cheeter slicks 26x11.5x15 www.intercotire.com i run drag radials on my stock rims,they hook better then a stock tire,but still spin too much.
Old 01-20-2007, 05:38 PM
ok well now your telling me something, i didnt know that, now i see why you need 325s
Quick Reply: Manual Trans and MT ET Street Radials
