Lights and turn signals
For you guys that remove pretty much all factory wiring, what methods do you use to retain the functionality of the lights and turn signals? I'm looking to pull out the rest of the factory wiring today and thought I'd get some input prior.
Thanks in advance.
Thanks in advance.
Tim, I pulled all the wiring from the engine compartment to under the dash. I rewired for my MSD ignition, starter and gauges. I didn't do anything with the lights and turn signal wiring. I figured it would be a waste of time to try and redo that. Plus it doesn't run from the computer so its okay not to mess with. I just took out what wasn't going to be used and then mounted and taped everything out of sight.
