Motor plate vs Motor Mount
8 Sec Tuner
The motor plate makes for a stiffer mount. It also gives you a good place to mount accessories (Vacume Pumps, Dry Sump Tanks, Breathers, Remote Oil Filters, ect.)...
-Ben R
-Ben R
I know the mid plate is useful as a sheild to protect the starter/engine from clutch/flywheel/flexplate explosion.
As far as using them vs motor mounts, I dont know. Couldnt find any info so I ordered solid mounts.
My '67 was still on stock motor mounts and after running it all year and plenty of 5 second 1/8 mile passes I found that one bolt had completely fell out into my diaper so I'm getting motor mounts here in a few weeks to prevent some of that flex.
Actually the one part I don't like about mounts in putting on fuel pump/Alternator/vacuum pump it gets crowded. My dad has a '70 Camaro and he is having a hard time getting an alternator to fit but his engine is set back and that's part of the problem.
Traditional motor mounts can cause strain on the side of the block in high hp cars, sometimes leading to cracking around the bolt bosses. I have also seen signs of ring seal getting better when side mounts are removed on high hp engines.
Kurt
Kurt
Do you guys always use a mid plate when going to motor plates? Is it always needed? I want to run a motor plate setup on my car to gain room for a 4.5-5 inch down pipe but dont want to mess with a mid plate. I dont want to have to add spacers to the flexplate or have the verter snout extended and all that. If it is a "have too" kinda thing with the mid plate then I will stick with what I have and built a custom passenger side solid mount.
We have ran cars without the mid plate, but prefer to use one when possible. If you need to lift in a wheelstand without a mid plate, the trans bellhousing may crack when you land.
Kurt
Kurt
Very true. My car is more of a street/Strip car with a big emphasis on track performance. It will probably see more roll races and weekend test 'n' tune nights than anything. I just wanna weigh my options out.
Im not running a mid plate.. i dont like the idea of shiming converters, my freind did it once and it was bad news... real bad vibrations. and broken converter bolts..
im running a front plate, on BMR's polymounts on the k-member and a trans mount. this is a big block 4th gen f-body.
another word of advise ive collected is you cant solid mount everything. if you run the plates, dont solid mount the trans, apparently it will blow the trans case under High HP
all depends on your plans, if its just a street car with weekend track trips, i wouldnt run plates. all out trailored drag car.. plates.. solid mount setups get old on the street quick
Its not really from a stand point of being an all out track car or needing the rigidity of the plate setup. It is strictly to gain more room on the passenger side of the engine to run a large down pipe for the turbo. Thats it. I just need more room.
