Mini Tub question
Mini Tub question
I have been looking at the wolf minitub and have a few questions.
will it do me any good to have a minitub without a narrowed rear? What's the widest tallest tire can I fit? what back spacing? what wheel size? if it needs to be narrowed, what is involved in that if I already have a moser 12 bolt?
98 Camaro
98 Camaro
You'll need to have the rear narrowed because you won't be able to get a wheel with enough backspacing. You'd have to send the back to Moser or find a racing shop that can shorten it for you. I'd say you should be able to run a 15x12 wheel with the minitub and narrowed rear.
A 15x12 with 7.5 bs will stick out the side of the car 1" more than a 15x10 with the same bs. It depends on how you want the wheel to sit on the fender. If you want it in the same location as a 15x10 with 7.5bs then you would narrow it 2".
If your buying the rearend at the time you have it narrowed its only about $50 more. If you've already got the rear it could cost you a couple hundred dollars. I ordered mine from Exotic Performance Plus and had it narrowed then. I actually don't think I paid any extra for it, or they were just having a good sale and it averaged out to the normal cost of a 9"
Originally Posted by 1fstTA
3" is the most you can go with and keep the factory mounting locations on suspension
not true, do a search for worm boy's 12 bolt. its narrowed like 5" per side and used stock pickup points. that may be the extreme but it is using factory mounting locations.
you can run the offset lca to move them over more but if you relocate the mounting brackets you eliminate yourself out of alot of the stock suspension class and the drag radial classes.
