Tires 4 launching w/trans brake
Just looking to see what the guys launching off the trans brake are using for tires. I'm more concerned with the sidewall of the tire. Are you using a stiffer sidewall or a softer one. The M6 guys benefit from a stiffer sidewall and auto's usually softer but not sure if launching off a trans brake?
Thanks.
Thanks.
what's up man!
i ran the 28x10.5" stiff side walla M/T's and they were awesome.
I've run the Hoosier 28x11.5 QTP's in my 6speed and they'd hook a low 1.4 on the 6000 dumps.
it's more of a suspension thing than a tire thing though. get the tire height correct for what you want to trap and your gearing.
Originally Posted by Slow00ls1T/a
what is weight of vehicle
if it is one the heavy side I would go with a stiffer sidewall due to all the weight
I pretty much thought I would need a stiffer side wall leaving off the trans brake but needed to be sure first. I have 3.25 gears and am looking to use a 28" tire.
second vote for goodyears with the D3 compound, i run 28x11x15's they work awesome. cut a 1.37 60ft with the back tires on them. They also make a 10in version of them thats .5 in shorter.
