what is the correct wat to setup a BMR extreme sway bar
do you just preload the **** ou of or what and when they mean preload is that pulling the right side bar up?
Motorboater
i was taught you unhook the endlinks from the bar, have someone as close to your bodyweight as possible sit in the drivers seat, and then set it up. same thing with your front ride height, etc. or you can just set the drivers side front height like 1/4" higher than the passenger side if no one is in the car. that's what i've always done. but last time i put my drag bar back on my 12 botl i had someone sitting in the car for me.
I guess not too many people use anti roll bars. I was curious on adj also ie make the links longer or shorter and how it effects weight transfer body roll and ultimately traction. Its too bad the thread died.
