Simple Rear sus for a Botlon car???
Well Ive got QAL-Rs up front, with no front sway bar, im going to get a perch and lower the front a lil bit. But what should I do with the rear sus? LCAs are on the list but what else?
I want to lower the rear but im not sure wich spring to use, also what shock to go with?...
Since this is a bolton car, I dont think I need a rear sway bar yet
Originally Posted by edwardswb
If you are planning to drag race I'd suggest not lowering it.
As long as you have a set of LCA relocation brackets you will be fine to lower it. I have QA1 Coilovers in the rear with a 150lb spring, and they work great. I have the car lowered to the tops of my 275/60/15 BFGs Drag radials and it looks pretty bad ***
Dan
Originally Posted by gator's 99TA
my car is lowered 2"
my car 60' in the 1.3 range on radials
Dan
Retired Street Racer
Originally Posted by SLPSS99
Your car is the one that always comes to mind when people say you cannot lower a car for drag racing because it will hurt you more then help, by the way you car looks great
Dan
Dan
Alan ran the Eibach Pro-Kit for awhile too. He was running mid to low 9s with a 6 speed.
Originally Posted by brandonppr
you could do adjustable spring perches and set the height yourself
I can set the front height, but I need somthing to lower the rear....
Prokits or somthing seem to sound good to me...
