To those running mufflers off of the headers
My car is stock internals and has 3" true duals with an x pipe, Sweet Thunders, and then dumps before the axle. I am looking to run the 18" total length (12" installed length) stainless Moroso Spiral Flows off of the 3" collectors (with no extensions), then either a 9" or 12" turndown after the mufflers. With the recent gains I have been seeing among the top SI cars, is there any reason why I shouldn't do it other than the noise increase? I plan on keeping it stock internals for quite some time, but do daily drive it, & will be taking it on the long haul for Power Tour. Let me know your thoughts guys, thanks!
Matt
Matt
Originally Posted by Taubr Unit
im doin the set up you got now matt. the x pipe with dumped bullets. ure car sounds badass
look for the mufflers SUX2BU ran. Those magnaflow's that are a "full body" muffler instead of a bullet, are a straight through design, but they definitely kept the noise down compared to the bullets that were on it.
i ran them off the mufflers and never got hassled. do a search in this section for that
I am looking to do the same except with a set of dynatech mufflers, here is a pic of them and a link to buy them!!
http://www.jegs.com/webapp/wcs/store...50918_-1_10265
Originally Posted by Slow Z28
Look for the mufflers SUX2BU ran. Those Magnaflow's that are a "full body" muffler instead of a bullet, are a straight through design, but they definitely kept the noise down compared to the bullets that were on it.
I put the Spiral Flows on like you're describing. Just clamped them to my headers and put dumps on them. The ground clearance on the DS is really bad. I am going to run some pipe to put the muffler in a better spot. The passenger side fits great.
BTW, didn't you used to run the same setup on the black car?
Its loud, not unbearable, but I don't think I'd DD it. Everyone is different though. I kept my 3" TD system with super turbos in one piece, I can swap exhausts in 20 or 30 minutes. The added room is nice though with the short system, I know that.
you'll have to bang either way... when i ran the single chamber flowmasters i had to on my old car as well
mine are the ones that SUX2BU got. they are like 9" wide, 4" tall, and 16 or 18" long, forgot which.
i didn't bang my floor at all, but then again they aren't tucked up like his were in the photos. mine were pointed down at an angle on the driver's side so it dind't mess with the seat re-inforcement area.
I wonder if I am going to have clearance issues with the oval Magnaflows...
i was planning on running this same setup. Was just going to hang dynomax bullets off the pacesetters, then put a turn down pointed towards the outside of the car, kinda at a 45* angle towards the outside. I know it will be loud, but after all, i like that sound :-)
How did the 1 Chambers fit off the headers, I was wondering if they would. I started a thread and got no replies!! Did they sound good?
Also does anyone have Pics of there off the header setups
Dan
Originally Posted by tuff
Matt its quite loud but my car is what it is.You might pull it off with the stocker,BTW why are you still running o2s put that thing in sd mode and be done with it.
8 SEC SLOPPY SHOT!!!
Originally Posted by Matt D
I daily drive it, including the winter time. I had thought about going SD, but I doubt I would see that much of an increase. I don't feel like messing with the tune after each pass. I just want to run the car and have fun without a hassle.
