Strange manual brake master questions...
I went ahead and put the manual master in today, I know it needs a new hole in the brake pedal, but where are you guys putting it? I've heard ~1/2 above the original location, and some have even posted 5/8...whats the skinny here? Also, does anyone have a pic of how it hooked up when finished? right now it would mount with the heim joint on the left of the actual pedal with a bolt going through there. Ehh...any help will be appreciated.
Matt
Matt
Billingsley Racing Manual Brake Kit Instructions
This Product is for Off-Highway Use Only
***ALTERING THE BRAKE SYSTEM ON ANY VEHICLE CAN BE POTENTIALLY DANGEROUS AND/OR FATAL IF INCORRECTLY INSTALLED AND RESULTING IN LOSS OF BRAKES~THIS PRODUCT SHOULD ONLY BE INSTALLED BY EXPERIENCED/COMPETANT INDIVIDUALS~ONCE INSTALLED ALL RESPONSIBILITY IS ASSUMED BY PURCHASER***
Remove the factory brake booster & master cylinder
When converting to a manual brake system, the pedal ratio will need to be altered:
Remove brake pedal assembly
Drill 3/8” dia. Hole 1” above the factory booster rod mounting rivet
Reassemble brake pedal assembly using aluminum firewall adapter included in this kit, and bolting the new master cylinder assembly to the firewall.
Reassemble brake pedal assembly using aluminum firewall adapter included in this kit, and bolting the new master cylinder assembly to the firewall.[/QUOTE]
Thats what I did and they work great. Moving the hole an inch higher gives it a straighter shot to the master cylinder.
