Skinnie tires, what are the lightest steet tires for skinnies
I know this should probably be in the wheels and tires section but i figured i would get a better response here. Like the title says what are the lightest skinnies tires that you can drive on the street and are NOT track only...include everything that you can thanks
Originally Posted by dkrvpro
I run the Mickey Thompson Sportsman 8 plys in a 26X7.50X15, mounted on 15 X 4 Bogart Welded RT's. I believe the 8 plys are safer on the street and track as my car sees double duty. I could give a damn about weight when I'm trapping at 120mph and dodging potholes.
what do they weigh the rims i got now are the convos with some 185/65/15 and they weigh in at a huge 29lb...i know the convos themselves weight about 9 lbs, so i am looking for a streetable tire what weighs less...my dad has some generic 165/65/15 but i heard that these are going to be hard to find...correct me if i am wrong...and he believes his weighed around ~24-25
Originally Posted by ninetres
I was going to make a separate thread (and still might) but try this on for size:
My 15x3.5" Bogart bolted D10s with 25" moroso DS2s: 22.6 lbs mounted
My friends 15x3.5" Bogart welded RTs with the cheapy 165/15 bug tires: 26.5 lbs
Originally Posted by xpndbl3
no you can't DD the DS2s they will overheat and blow out. Two of my friends had them blow out on separate nights
I just figured it was the lack of tread that made them unsafe.
Can I turtle out to the local track on them?
