Drag Racing Tech
What e.t. difference with Drag wheels compared to stock?
Old 04-06-2007, 09:44 AM
Dr. Jeckel's Avatar
Default What e.t. difference with Drag wheels compared to stock?
Has anyone made a comparison between stock 17" wheels with 275 DR's and a set of 15" drag wheels with 275 DR's (3.5" front and 8" rear wide)?
I am trying to find concrete numbers as to what kinda e.t. gains there are by switching, since I know its about a 70-80 pound weight drop, but what does that translate into at the track?
I would like to negate the traction difference, but realize that would be hard, since the 15" DR's are gonna give better traction because of the larger sidewall. I am really wanting to know what kinda gains will be realized from the lighter wheel/tire combo.
Please, someone that has raced there car with each type, give me some numbers between the two.
Thank you, James.
Old 04-06-2007, 12:55 PM
Retired Street Racer
Matt D's Avatar
It's hard to get concrete numbers as track conditions, weather, etc, play a factor in it.
Old 04-06-2007, 01:04 PM
JUICED96Z
Guest
Posts: n/a
Matt speaks the truth and its the same with all mods.
One day a cam might run .8 faster, the next .7.
All depends on the track and weather conditions.
Old 04-06-2007, 01:19 PM
WS6HUMMER's Avatar
I just found out last weekend. Before I ran an MT slick on a 15 x 7 wheel, now I have 15x10's and 15x3.5's up front. I yoused to have to try to get a 1.7 60 in my M6 car, now every run is a 1.7 without even trying and I picked up a tenth in the 1/8th (havent had the chance to go 1/4 yet). Also I always mark the bead and the rim, now that I have the appropriate width wheel on the back I noticed the bead spun on the launch, that never happened with the old wheels. The worse part of the whole thing was devoting a solid weekend to caliper grinding.
Old 04-06-2007, 01:47 PM
Dr. Jeckel's Avatar
I realize it is hard to get numbers from gains, but if you have only one variable, which in this case would be the wheels, someone should have some kinda numbers. I'm just trying to figure out a rough estimate, like does it give you .1 or .4...I'm trying to figure out an average to just spending the money. The runs would need to be somewhat near each other (a few days), for weather variables to not really affect the outcome.
I am basically looking for a statement like this;
"I had 17" wheels with drag radials and ran a XXX e.t. at the track, then I switched to 15" drag wheels with drag radials and ran XXX e.t."
If some can make such a comment, then this is what I am looking for, not really the reasons for it being hard to get the numbers
WS6HUMMER, do you have an comparison between your stock wheels and the drag wheels? This is what I'm really after.
Old 04-06-2007, 02:03 PM
NA$TY-TA's Avatar
Thank you, James.
Ive always been told that every 100 lbs is worth a tenth(.10)
The weight gone and the same 60" as before you should be faster....
Old 04-06-2007, 02:05 PM
black_z's Avatar
The gain is much higher when you are talking about unsprung weight....
Old 04-06-2007, 02:08 PM
WS6HUMMER's Avatar
Yeah I do, the 15's are a HUGE advantage than the 17's. I got a best of 1.9 60' on 17's with the Nitto DR's and a 1.8 on some 15x7's with a very hard worn out set of BFG DR's. If you go with 15x10's and a slick or even a Hooser DOT QTP you WILL see a positive gain. The #'s are all up to you but I can tell you from my own experience that a better tire with more sidewall will knock tenths off your ET if you have an M6 car.
Old 04-06-2007, 02:09 PM
Bryan @ Speed Inc.'s Avatar
true dat!
usually you don't take off much weight on the rears - it's all in the skinnies. i'd say most people have experienced, around 1.5-.2 going from stock front wheels and tires to skinnies.
i gained a solid .2 in my orange car - went from 11.42 to 11.22. but those runs were made two weeks apart so weather could have been different.
Old 04-06-2007, 02:12 PM
WS6HUMMER's Avatar
Originally Posted by imslow
true dat!
Were the 60's the same or did they improve with your skinnies?
Old 04-06-2007, 04:00 PM
Dr. Jeckel's Avatar
true dat!
Thank you, that was exactly what I was looking for. You loose about 20lbs from the rears and 50lbs from the fronts. In everything I have read only a handful of people actually mentioned a number(that they heard) and that was .2, but I just wanted to hear it from someone first hand.
Old 04-06-2007, 04:35 PM
98 Z-28's Avatar
I ran a 8.5x in the 1\8 with 245\50\16 street tires and i put on some Draglites with Micky Thompson Street ET Drag Radials 275/50/15 (on DR's with 15'' Wheels) and I ran a 8.141 that was a .4 diffrence in the 1\8 mile I was happy also got .3 in my 60' also but thats a given with DR's
The main thing I noticed 2nd Gear was just a little spin instead of a smoke show I reccomend a line lock for an M6 (me) because you gotta really heat them Dr's up in the water box
Starting off like I said i got 3 tenths in the 60'' almost a dead hook off the line I should have took the frount sway bar off stupid me !!! it just spun the very begining of 2nd and 3rd no spin at all on a good run on my street tires 3rd would chirp a little now its the same but in 2nd gear difference is night and day i got 4 tenths (.4 off my et in an 1\8 mile) pretty good mod Id say
Old 04-06-2007, 05:02 PM
Dr. Jeckel's Avatar
I wouldn't burn BFG or MT DR's, I was always told that a light hazing would do great.....now e.t. streets and Nittos are a different story.
Old 04-06-2007, 05:11 PM
1320FEVER's Avatar
When you take weight away from rotating mass like front wheels it has a much more effect than the equivalent of static mass (if that makes any sense). Thats why light wheels are a worthwhile mod (in my opinion).
Old 04-06-2007, 07:02 PM
02SS:ZEUS's Avatar
In other words...taking 50lbs off the front wheels is kind of like taking 200lbs off the car. Less rotating mass. Maybe that'll help.
Old 04-06-2007, 09:24 PM
Dan
Dan's Avatar
I picked up a tenth & a half on the same day from Street tires 16" to front skinnies..
Old 04-06-2007, 09:48 PM
deejaydaze's Avatar
http://www.mickeythompsontires.com/tech.php?bulletin=s1
Pointed out by a buddy of mine
Old 04-07-2007, 11:44 AM
purdueranger's Avatar
I went from 315/35R17 Nitto 555R on 17x11 Wheels to 26x10.50R16 ET Streets and I cut .50 off of my ET. These two runs were within 2.5 weeks from each other.
Old 04-07-2007, 02:07 PM
1cdub's Avatar
On the old SS, I picked up over .5 sec. Went from Stock ZR1's all around to 15" Telstars running skinnies and slicks.
Car ran 13.10's all day. 100% STOCK, not even a lid. Added nothing, took nothing away, other than the wheel and tire swap and it ran 12.5x's all day. Car was an 01' 6spd btw.
Old 04-07-2007, 02:56 PM
Candyredz28's Avatar
Well I got C5 wheels in the back which are 18's and was wondering If I will gain anything if i put my 27x10.5/15 hoosier slicks with pro stars or is this too much tire for me?
Quick Reply: What e.t. difference with Drag wheels compared to stock?
