New best 10.632 @132.29
First off thanks Jason at Thunder Craig @ GTP and Alan at FMS for helping me to get this car set up this time around
Well today was a blast even though the track was not hooking near as good in the past + the D/A SUCKED setting in at 2515 and it was about 96 degrees out as well.I let someone barrow the 28" ET Drags I had I and couldnt get them back in time for today so I had to run a 27" Hoosier QTP 9" wide . I think the car had some 11.2's in it today if it would have hooked but I Managed to check out the new new set up on a few motor passes these were some of the N/A times of the day hopefully come winter and some good air the car will see some 10's on motor ....
11.427 @ 120.41 60" 1.603
11.441 @ 120.65 60" 1.616
then comes the spray passes the first pass was on a 100 shot
10.980 @ 128.15 60" 1.615
Then decided to try a both stages of N20 out of the whole which was a 150 shot and smoked the clutch really bad. This pass I think would have been awsome if the clutch did stick to the floor I had a 1.511 60" but the car went no where after the launch.....
So 20 minutes later I went back at it came out with the hundred shot then hit the 50 shot in 2nd and the results were.
1.541 60"
103.85 1/8
6.909 1/8
10.631 1/4
132 MPH
1.541 60"
103.85 1/8
6.909 1/8
10.631 1/4
132 MPH
Re: New best 10.632 @132.29
The clutch was slipping coming out of the whole @ 6K on the 150 shot but would hold on the 100. So I Launched on a 100 shoot and then when I shifted into 2nd I hit the 50 shot on top of the 100 shot and then I let out of the 50 shot @ about 6400 in 4th and let the 100 shot pull the rest of the way through 4th since I dont have a NOS tune I didnt want to spray the 150 all the way through 4th due to the tunning . Kind of confussing but I hope this helped I wanted to make another pass and try a to up the 2nd stage to a 100 as well but they made me pull the bottle.
Thanks Rob & Jason Hopefully I will be back at the track in a few weeks I dont think the weather could get much worse then today
11.427@ 120.41 1.603 60 N/A D/A 2515
Corrected Time is approx. 11.089 @ 124.15
That is Hauling ***. At sea level with a little better launch 10.9x N/A for sure
Congrats!
Congrats!
If it were an LT1, I would tell you to go McLeod Street Twin but I dont know what the BEST clutch is for an LS1. Get a clutch in it, spray it with the 100/100 and have some fun!
Congrats on the new bests, that is moving out for sure!
The DA was only around +1616 at 1pm, so come winter you should be looking good in the 10's NA.
I watched the video finally today and it seems I need Slicks Bad + a wider Tire. I smoked the tires past the 60' mark lol Maybe a 10.3 was in the cards if it would have hooked
A few people at the track that day that run Mustangs and GN's were telling me the DA was in the low 2500's they had hand held Gizmo's I checked it out after I got home to use my computer and later in the day after I got home it said the DA was 2480. Maybe we are al checking it out wrong :p Its nothing to bitch about the car was running great for the little work that is done to it so im happy One more thing :p
You said it! :p
