Good DA Calculator
LS1TECH Sponsor
Good DA Calculator
Enjoy:
http://wahiduddin.net/calc/calc_hp_abs.htm
Make sure to add your tracks actual elevation to the DA since this is corrected to sea level.
Mikey
Mikey
Re: Good DA Calculator
i have been using this one, from the same site. it has an input for track elevation:
http://wahiduddin.net/calc/calc_da.htm
http://www.lamtec.com/dew-point-calculator.htm has a chart you can print to convert RH to dew point.
www.wunderground is an excellent site for getting historical weather data (they go back a coupe years), all you need is the ZIP code to the track and its usually pretty close. The popups are annoying so I just give the 5.00 a year they ask for to get rid of them
