Painting cage? - LS1TECH
Painting cage?
Thread Tools Search this Thread
Old 08-01-2007, 09:24 AM   #1
LS1Tech Sponsor
Default Painting cage?
Whats a good strong paint? I'll be doing my 25.5 setup soon and would like to only do it once Was thinking ussing the POR 15 system. Any other strong paint's out there? Have a ton of pipes and frame work to do.
Slowhawk is offline   Reply With Quote
Old 08-01-2007, 09:38 AM   #2
VHT self priming epoxy paint.
JeffT is offline   Reply With Quote
Old 08-01-2007, 10:07 AM   #3
turkey's Avatar
We have used the Por-15 on a few cages, covers nice and definately strong enough to last.
turkey is offline   Reply With Quote
Old 08-01-2007, 12:11 PM   #4
Race your car!
get some of that self leveling epoxy based urethane paint that's commonly used on boats.... that's what I used and it's hard as nails once it dries. I haven't scratched it yet, and it covers pretty good too, 2 coats on everything and it will be good to go.
JL ws-6 is offline   Reply With Quote
Old 08-02-2007, 03:10 PM   #5
Dumb Ass Vette Moderator
ls1290's Avatar
I did mine with Por-15 paint and clearcoat. Still holding and looking good after 4 years
Keith
ls1290 is offline   Reply With Quote
Old 08-02-2007, 03:29 PM   #6
LS1Tech Sponsor
Nice seeing the POR result's I've used it on rears but just wanted to check.Only plan on doing this once.
Old 08-02-2007, 10:18 PM   #7
7 Second Club
Phil99vette's Avatar
I can't get POR15 to lay smooth. Mine always has air bubbles and can never get it smooth now matter how little or much paint I use.
Phil99vette is offline   Reply With Quote
Old 08-02-2007, 10:33 PM   #8
DRAG RACING IS LIFE! Mod
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
I would have used POR-15 now, but mine is done in matching green color on the Nova. Use clear to help with the chipping if you try to match colors, otherwise POR is the way to go IMHO. I'll be doing my entire undercarriage with it shortly for the same reason you mentioned on what to use: It should last a long time!
Derek
Villain281H is offline   Reply With Quote
Old 08-03-2007, 08:32 AM   #9
ls1290's Avatar
Quote:
Thin it down just a little( and I mean a little ) and it will dry smooth.
Keith
Old 08-03-2007, 02:29 PM   #10
8 second mod
Noyzee's Avatar
i primed mine with a spray bomb self etching primmer and painted it with a metalic krylon 2 coats then a coat of clear. it looks real good. the only scratches are where i get in and out, but its padded anyway so it all got covered.
the por 15 would probably work well also.
Noyzee is offline   Reply With Quote
Tags
epoxy, etching, paint, vht
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
