Drag Racing Tech
my final purchases to go for 10's were made today.
Old 05-20-2003, 05:54 PM
MIGHTYMOUSE's Avatar
Default my final purchases to go for 10's were made today.
15*10 prostars and 27*11.5 quick time pro's
a spohn tq arm with front loop and a spohn adj. phr.
i figure if i can put these together to come up with a 1.6 short time im there... and a few extra pounds of boost for good measure
questions.. is the pinion angle obvious to set.. for a manual car should i go -3 or -4* and does it matter that the car is lowered for that setting?
i wanted the 28" tires but i have enough gear (3.73) to get to 133mph with the 27's and the fit under the car will be overly tight as-is.. hopefully no cutting aside from the calipers and a little fender well clearancing..
what do you guys think? am i leaving anything out?.. should i get a set of airbags in? i really dont want to put the stock springs back in back. also what kind of times are manual guys cutting with these 11.5 quicktime drag dot tires?
i have the hal's around with their springs in front. 2 step launches of course
comments appreciated.
Dave
Old 05-20-2003, 09:03 PM
02 Silver Z's Avatar
Default Re: my final purchases to go for 10's were made today.
Good luck dude! Go get them 10`s!!
Old 05-20-2003, 10:59 PM
BIGBOS's Avatar
I'm running the same rims and tires on the back...click on my name to the left and look at my webshots..
There was A LOT of grinded needed on both sides...
The bump stops had to be completely grinded off, that took some time...
A little pounding on the inside of the fender wall cleared the inner front of the tire...
Also I'm running extended studs because I grinded to the point to where they cleared with the 5/16 spacer...
Its involved, but well worth it when your done...
Old 05-21-2003, 09:28 AM
LOnSLO's Avatar
My best short time was a 1.54 with the 27 x 11.5 Hoosier QTPs.
Old 05-22-2003, 04:19 PM
man i tell you what summit is FAST
ordered tuesday afternoon, here thurs afternoon
http://community.webshots.com/photo/...74083105zDoiTu
Old 05-25-2003, 11:33 AM
and here they are, more info in tire section
Old 05-25-2003, 01:42 PM
LOnSLO's Avatar
NICE!!! I love the way those Pro Stars look on T/A's. Now get out there and burn those things in!
Old 05-26-2003, 03:57 PM
99OrangeSS's Avatar
Man your car looks sweet... Did you have any issues with clearance? When are you going to the track to shoot for 10's.
Old 05-26-2003, 11:01 PM
i worked on the wastegate problem all day today with no progress.. i will have to try another spring or another gate all together before its good for a few more mph to get me there.
Quick Reply: my final purchases to go for 10's were made today.
