Drag Racing Tech
G5X-2 Breaks the 'Cam only' record again.
Old 05-24-2003, 05:01 PM
The Juggernaut's Avatar
Default G5X-2 Breaks the 'Cam only' record again.
US41,the MFBA track rental.
I don't know what the DA was(+1000?)small tail wind.
Raceweight around 3100(give or take 10#)
I ripped off a 11.086@123.63(1.569) backed by some 11.1's and 11.2's.
11.4 with traction problems and an 11.6 with traction problems and missing 4th gear.
I have a few more tricks up my sleeve and I will see a 10 sec time slip by fall.
Mike H.-I'm comin' for ya.
LG Motorsports'G5X-2 kickin' some SERIOUS ***!
Old 05-24-2003, 05:46 PM
GrannySShifting's Avatar
Default Re: G5X-2 Breaks the 'Cam only' record again.
Daz rollin
Old 05-24-2003, 06:56 PM
Shorty Director
VINCE's Avatar
How did you break the cam only record? Those are awesome times, but I think someone has already ran 10.98's with cam only.. I would check Futral Motorsports website or the tab that says ls1tech.com members 1/4th mile ET lists.. Mike H. is the cam only champ right now at 3300lbs.. I still have to give you props though. That is crazy fast..
Old 05-24-2003, 07:10 PM
Sorry,
M6 cam only.(That's why I said that I was comin'
for Mike H.(Hoffpaur(sp?)-10.98 A4).
No stab-n-steer here.
Old 05-24-2003, 07:31 PM
Shorty Director
VINCE's Avatar
You did it with a M6? Wow!!! That is really impressive.. Congrats!!!!!!!!!!!!!!!!!!!!!!
Old 05-24-2003, 08:08 PM
The DA was +1669,9 mph tail wind.
Rock on.
Old 05-24-2003, 08:36 PM
DriveATransAm's Avatar
i call bs
nice runs.
we both spun big time against each other
i need to loose 200 pounds so we run about the same
Old 05-24-2003, 08:50 PM
Kent1's Avatar
Nice run with a 6 spd. That GX-2 cam is moving. Simply amazing. Cheers
Old 05-24-2003, 10:45 PM
2000SILVERTA's Avatar
nice times.
with that raceweight Im guessing your AC aint very cold?
Old 05-25-2003, 12:47 AM
BIGBOS's Avatar
Impressive times, congrats...
Old 05-25-2003, 02:22 AM
oOoLy's Avatar
Congrats... very nice time
Old 05-25-2003, 02:55 AM
Abdulla's Avatar
Congratulatio man , you are really The Quickest N/A Cam Only M6 I ever heard of
Waiting for your 10s pass
Good luck
Old 05-25-2003, 07:17 AM
Administrator
unit213's Avatar
That is haulin' ***. Nice work! What bolt-ons do you have?
Old 05-25-2003, 08:30 AM
Super Moderator
Reckless's Avatar
Really impressive. Better than I ran with 150 jets on Friday
Gotta get me one of those cams
Old 05-25-2003, 08:46 AM
LS1 SPEED INC.'s Avatar
Sean the car is flying,good luck with your goal.
We need some of that -DA so we can really get our cars moving
It was a great time yesterday
see you soon
Larry
Old 05-25-2003, 10:30 AM
A/C? Bolt-on's?
ALL the bolt-ons,none of the weight.
Old 05-25-2003, 10:55 AM
butcher1's Avatar
11.08? What a pooch! I'm less than a second behind you on the same track and
in the same air , and my car is completely stock. I'm sure I can make that up with
a good reaction time and with power shifting. :p If you change the clutch fluid
and go back to the track on a Friday or Saturday night , you should be able to get
into the 10's. So close and yet so far away.
Old 05-25-2003, 11:24 AM
98TAauto's Avatar
I call BS also.. it just cant be done as some would say.. NOT
HEHEHEH congrats man!! Cut Mike a little slack now. We cant have these M6's beating the A4 record! LMAO
Old 05-25-2003, 12:28 PM
Bear's Avatar
I hope to hit that time or slightly better with A 409!!!! My car and I are very heavy. U must be stoked to hit that number. Keep on
Old 05-25-2003, 01:36 PM
Crunch's Avatar
3100 lb. raceweight?!!
If the driver weighs 200lbs, then the car is really only 2900lbs.
Not saying the car ain't fast as hell, but don't forget it weighs 600 lbs less than a full weight car.
Drop 600 lbs off some of the other 11 sec cam-only LS1 cars out here, and I'm sure your'e talkin' 11.00's as well. It's just that most people dont go through the trouble of putting their car on a 600 lb. Jenny Craig diet.
Congratulations on having a fat-free low cholestorol car!
