How in gods name do you wrap the "wrap around" 5pt?
I am an idiot... I can't figure out how you wrap the harness around the crossbar of the rollbar?
I have an RJS dual shoulder 5 point harness.
Any help appreciated, especially pics etc (For my brain damaged mind...)
thanks!
Chris
thanks!
Chris
Resident Grump
Re: How in gods name do you wrap the
I'll try Chris. Run said harness in, over, down and out the piece with two slots around cross bar and then back out the way you came in. I know that sonds silly but try it. It works!!
I think I got it now I will go check to make sure it is like you described
Thanks Joe!
Now if I could only find my torx for getting the damn seatbelts out haha!
Thanks Joe!
Yep I got the crossbar part right
I have a question has anyone used the rear seat mounting studs to mount the "side belt" part of the harness? I tried using the stock seatbelt bolts but they weren't long enough. I'll pickup longer bolts tomorrow if you guys think using the rear two seat mounting studs/bolts isnt secure enough. (I am pretty sure I'll need to move them but I was curious if it was enough
I also need to get a longer bolt/wide washer setup so I can drill through the floorboard for the crotch strap.
Cheers,
Chris
Cheers,
Chris
Chris - I couldn't find a bolt that matched the thread at my hardware store. Maybe i'm stupid, but its possible its a tappered thread of somesort. I ended up taking my stock seatbelt bolts and putting them on a lathe and turning the shank down some.
