Got my 1st set of M/T dr's
Finally. I honestly couldn't pass up the deal. They had 18 miles on em and I gave $150 for the set, they look almost new. So they will get mounted up this evening. I drive the car a couple of times a week 15 miles round trip, what tire psi do you guys run on the street? Is it safe to keep em at around 20-22? Just trying to do a lil homework to see if I can get em to work for me.
I'd put 30psi in them for driving around and see how the hook is...Go down from there if necessary.
They'll probably still stick like mad at that psi once warmed up on the street
x2. I had to slow down to almost 35 mph on the highway, and I still almost put my car into the gaurd rail a few times. It felt like the rearend of my car wasn't connected and it wanted to drive right out from under me.
I don't run over 25 psi on the street with my 275 60 R15s...You'll wear the centers out real fast with too much air on the street...I check the wear with my daughter's driveway chalk...I run a chalk line across the tread and drive it down the street and check how the chalk wears and adjust the psi accordingly...
--Alan
--Alan
i use 22psi all the time. the only street miles they usually see is to the track and car meets. They definately suck in the rain. i was in 5th gear going 50mph once, stepped on the gas a lil and it went sideways, i am not bullshitting you. Do not do dry burnouts with those tires, not even a little one for they will get torn up very quickly. i found that out the hard way with my first pair..
You're killing me Alan! The chalk idea is brilliant though, thanks!
I haven't had mine very long. And it's been long enough to know that I'll never run anything else! Been caught in the rain once. I pray it never happens again. It IS a whole lot more fun being able to use the gas pedal on the street now. Can't waight to get them to the track in the spring so I can finally get a decent 60' and maybe an 11.9X. Have fun with them.
